Cura 3.0.3 won't open
Printers_Unite
Posted · Cura 3.0.3 won't open
Right so this is a little inconvenient due to the brand new release of the slicer but still (this happened with 2.7 as well);
Everytime I try to open the software, it launches the loading stuff but, when it finished loading machines, it closes. It doesn't even register as an open application (I opened it and then went onto task manager and it didn't appear). I reinstalled 2.6 (because that was the last one that worked with me) and after it loaded machines, it open the software straight away; no problem opening it.
I opened the software through admin and I've reinstalled it a few times; I've also gone to the file location and opened it directly there.
I'm not an advance programmer (Nor one at all) so if you do try to help (thanks in advance) please use simple english ahah
Thanks!
    I recommend deleting everything you ever saved in cura. It should all be in %appdata%/cura. Then when you re-launch 3.0.3 it will create those folders fresh.
    Posted (edited) · Cura 3.0.3 won't open
    I have same issue.  So I deleted all the Appdata from local and roaming and the Cura then progresses a little farther into opening, which it didnt do before.  It now opens but then when I try to select a printer type or even try to create a custom type it crashes again.  Same as before.  If i close the printer selection I can get to the cura interface but without anything else because printer isnt defined yet.  Anyone have any ideas for that?  I uploaded my cura.log from appdata/roaming cura 3.0 folder if it help
    Cura log
    I'm having the same problem. downloaded several times installed 4 times now. uninstalled rebooted and installed deleting all directories in appdata each time. NO JOY! It gets to the point of picking the printer, you select i9t and next, crash every time. oh, and I've tried different printers. Also, NO JOY! Funny how some people have version 3.0.2 and all you can download now is 3.0.3. It's full of bugs my friends!
    Yes. All directories and all versions were removed. Ran CCleaner and rebooted. Reinstalled and still does not work. Reinstalled net framework 4.7 and still does not work.
    Did same thing. deleted every instance of cura in program files, appdata and anywhere else I can find. Updated all windows 7 updates so everything is up to date but keep getting same thing. Only thing I can think of is something in the log. The log has multiple errors about loading: "ERROR - UM.Logger.logException" if you look in the log I posted above. Windows event viewer has some error about office .dll that has something to do with Intel graphics but that is updated also with same Cura error. Is any one else with errors using an integrated Intel Graphics Chip? maybe that is the issue? Using a Toshiba Satellite C655-S5235. Any suggestion would be great. Thanks
    Devs: CURA-4468
    Hello @Printers_Unite, you said that this problem happens with Cura 2.7 and Cura 3.0.
    Can you tell me what printers (and their configuration) do you have in 2.6?
    Alternatively, do you still happen to have your two cura folders in \AppData\Local and in \AppData\Roaming? If you won't mind, you can upload them so that I can take a look at the configuration you have and then check why Cura does not launch for you at all.
    Yea so it works with 2.6 perfectly fine. I do have all three folders! I have a custom profile for my CR-10. How do I upload it?
    When you say everything... what exactly? Like which folder to delete? Thanks!
    *EDIT*
    Found what you meant but sadly no change. I will re-download 2.7 and run it (if it crashes I'll soft reset it) and I'll edit this post again
    *EDIT after running 2.7*
    So 2.7 now works; I deleted the roaming data folder
    *EDIT after running 3.0 again*
    And now it works.... AWESOME! Thanks so much!
    Everything after the *EDIT*
    After downloading Cura 3.0.3 (64bit) installer for Windows, my Symantec Endpoint Protection moved the installer to quarantine saying that "there is a strong evidence that this file is untrustworthy". I'm an administrator on this windows (can install apps etc.), but can't disable Symantec even for a while (company policy). Can you suggest something? Perhaps someone from Cura team could check the installer....?
    Thanks in advance.
    Hi
    where do I find that Folder on Win10 ? %appdata%/cura nothing in C or Programme oder user..
    Sorry working more on Mac...
    I want test the new version but I have this problem. Even after delete .cura and appdata...cura directory and all oldest version.
    In the log file (stderr.log) I can read line 103 : "Fatal Python error : Aborted"
    Im still having an issue.  2.7 works fine but 3.0.3 doesnt.  I posted log above but here is newest one after doing all this. Deleted appdata from both local and roaming, uninstalled, ccleaned directories and registry, reinstalled with same issue.  Can anyone look at my log and help pleaseee.  Im missing out on all the new fun stuff with 3.0.  Thanks
    Cura log from "local" https://www.scribd.com/document/362122251/Cura-log-txt
    stdder log from "roaming" https://www.scribd.com/document/362122194/stderr-log-txt
    I can run 2.7 fine but 3.0.3 crashes if I select a printer. I've uninstalled both and deleted both folders in local and roaming. Still closes.
    I tryed with 2.7, this version is fine. I select my Ultimaker Original + printer and start ok.
    I work with 15.04.3 and I like save project files function and material profils on this 2.7.
    After this I reinstall 3.03, but crash when I validate printer select window.
    I search with this new version a better surface finish, because trajectory of the head is bad when we have 2 top surface very nigh.
    EDIT 22/10/2017: Congratulations for Cura 2.7, very good job, with 1mm Z offset + good inter-lines space + head trajectory mix choice, the finish of top is very very nice.
    Try to delite app roaming and local. Stil crash when i choise printer.
    My log:
    2017-10-21 15:29:42,480 - INFO - UM.PluginRegistry.loadPlugin [238]: Loaded plugin FileLogger
    2017-10-21 15:29:42,490 - INFO - UM.PluginRegistry.loadPlugin [238]: Loaded plugin GCodeProfileReader
    2017-10-21 15:29:42,502 - INFO - UM.PluginRegistry.loadPlugin [238]: Loaded plugin GCodeReader
    2017-10-21 15:29:42,512 - INFO - UM.PluginRegistry.loadPlugin [238]: Loaded plugin GCodeWriter
    2017-10-21 15:29:42,523 - INFO - UM.PluginRegistry.loadPlugin [238]: Loaded plugin ImageReader
    2017-10-21 15:29:42,541 - INFO - UM.PluginRegistry.loadPlugin [238]: Loaded plugin LayerView
    2017-10-21 15:29:42,552 - INFO - UM.PluginRegistry.loadPlugin [238]: Loaded plugin LegacyProfileReader
    2017-10-21 15:29:42,566 - INFO - UM.PluginRegistry.loadPlugin [238]: Loaded plugin LocalFileOutputDevice
    2017-10-21 15:29:42,579 - INFO - UM.PluginRegistry.loadPlugin [238]: Loaded plugin MachineSettingsAction
    2017-10-21 15:29:42,701 - INFO - UM.PluginRegistry.loadPlugin [238]: Loaded plugin OctoPrintPlugin
    2017-10-21 15:29:42,715 - WARNING - UM.Preferences.getValue [81]: Tried to get the value of non-existing setting cura/active_mode.
    2017-10-21 15:29:42,717 - INFO - UM.PluginRegistry.loadPlugin [238]: Loaded plugin PerObjectSettingsTool
    2017-10-21 15:29:42,727 - INFO - UM.PluginRegistry.loadPlugin [238]: Loaded plugin PluginBrowser
    2017-10-21 15:29:42,740 - INFO - UM.PluginRegistry.loadPlugin [238]: Loaded plugin PostProcessingPlugin
    2017-10-21 15:29:42,758 - INFO - UM.PluginRegistry.loadPlugin [238]: Loaded plugin RemovableDriveOutputDevice
    2017-10-21 15:29:42,818 - INFO - UM.PluginRegistry.loadPlugin [238]: Loaded plugin SliceInfoPlugin
    2017-10-21 15:29:42,830 - INFO - UM.PluginRegistry.loadPlugin [238]: Loaded plugin SolidView
    2017-10-21 15:29:42,843 - INFO - UM.PluginRegistry.loadPlugin [238]: Loaded plugin CameraTool
    2017-10-21 15:29:42,857 - INFO - UM.PluginRegistry.loadPlugin [238]: Loaded plugin MirrorTool
    2017-10-21 15:29:42,873 - INFO - UM.PluginRegistry.loadPlugin [238]: Loaded plugin RotateTool
    2017-10-21 15:29:42,888 - INFO - UM.PluginRegistry.loadPlugin [238]: Loaded plugin ScaleTool
    2017-10-21 15:29:42,901 - INFO - UM.PluginRegistry.loadPlugin [238]: Loaded plugin SelectionTool
    2017-10-21 15:29:42,914 - INFO - UM.PluginRegistry.loadPlugin [238]: Loaded plugin TranslateTool
    2017-10-21 15:29:42,934 - INFO - UM.PluginRegistry.loadPlugin [238]: Loaded plugin UltimakerMachineActions
    2017-10-21 15:29:42,991 - INFO - UM.PluginRegistry.loadPlugin [238]: Loaded plugin UM3NetworkPrinting
    2017-10-21 15:29:43,007 - INFO - UM.PluginRegistry.loadPlugin [238]: Loaded plugin UpdateChecker
    2017-10-21 15:29:43,012 - INFO - UpdateChecker.UpdateCheckerJob.run [44]: Checking for new version of cura
    2017-10-21 15:29:43,046 - INFO - UM.PluginRegistry.loadPlugin [238]: Loaded plugin USBPrinting
    2017-10-21 15:29:43,064 - INFO - UM.PluginRegistry.loadPlugin [238]: Loaded plugin VersionUpgrade21to22
    2017-10-21 15:29:43,078 - INFO - UM.PluginRegistry.loadPlugin [238]: Loaded plugin VersionUpgrade22to24
    2017-10-21 15:29:43,092 - INFO - UM.PluginRegistry.loadPlugin [238]: Loaded plugin VersionUpgrade25to26
    2017-10-21 15:29:43,107 - INFO - UM.PluginRegistry.loadPlugin [238]: Loaded plugin VersionUpgrade26to27
    2017-10-21 15:29:43,120 - INFO - UM.PluginRegistry.loadPlugin [238]: Loaded plugin VersionUpgrade27to30
    2017-10-21 15:29:43,135 - INFO - UM.PluginRegistry.loadPlugin [238]: Loaded plugin SimpleView
    2017-10-21 15:29:43,152 - INFO - UM.PluginRegistry.loadPlugin [238]: Loaded plugin X3DReader
    2017-10-21 15:29:43,169 - INFO - UM.PluginRegistry.loadPlugin [238]: Loaded plugin XmlMaterialProfile
    2017-10-21 15:29:43,186 - INFO - UM.PluginRegistry.loadPlugin [238]: Loaded plugin XRayView
    2017-10-21 15:29:43,189 - INFO - UM.Qt.QtApplication.__init__ [114]: Command line arguments: {'qmljsdebugger': None, 'single_instance': False, 'disable-textures': False, 'external-backend': False, 'file': []}
    2017-10-21 15:29:43,206 - INFO - UM.VersionUpgradeManager.upgrade [112]: Looking for old configuration files to upgrade.
    2017-10-21 15:29:43,214 - DEBUG - UM.Backend.Backend._logSocketState [174]: Socket state changed to Listening
    2017-10-21 15:29:43,220 - INFO - UM.Backend.Backend.startEngine [75]: Started engine process: C:\Program Files\Cura 3.0\CuraEngine.exe
    2017-10-21 15:29:43,224 - DEBUG - UM.Backend.Backend._backendLog [93]: [backend] Calling engine with: ['C:\\Program Files\\Cura 3.0\\CuraEngine.exe', 'connect', '127.0.0.1:49674', '-j', 'C:\\Program Files\\Cura 3.0\\resources\\definitions\\fdmprinter.def.json', '']
    2017-10-21 15:29:43,361 - DEBUG - UM.Backend.Backend._backendLog [93]: [backend]
    2017-10-21 15:29:43,363 - DEBUG - UM.Backend.Backend._backendLog [93]: [backend] Cura_SteamEngine version DEV
    2017-10-21 15:29:43,368 - DEBUG - UM.Backend.Backend._backendLog [93]: [backend] Copyright (C) 2017 Ultimaker
    2017-10-21 15:29:43,373 - DEBUG - UM.Backend.Backend._backendLog [93]: [backend]
    2017-10-21 15:29:43,376 - DEBUG - UM.Backend.Backend._backendLog [93]: [backend] This program is free software: you can redistribute it and/or modify
    2017-10-21 15:29:43,379 - DEBUG - UM.Backend.Backend._backendLog [93]: [backend] it under the terms of the GNU Affero General Public License as published by
    2017-10-21 15:29:43,381 - DEBUG - UM.Backend.Backend._backendLog [93]: [backend] the Free Software Foundation, either version 3 of the License, or
    2017-10-21 15:29:43,384 - DEBUG - UM.Backend.Backend._backendLog [93]: [backend] (at your option) any later version.
    2017-10-21 15:29:43,387 - DEBUG - UM.Backend.Backend._backendLog [93]: [backend]
    2017-10-21 15:29:43,389 - DEBUG - UM.Backend.Backend._backendLog [93]: [backend] This program is distributed in the hope that it will be useful,
    2017-10-21 15:29:43,392 - DEBUG - UM.Backend.Backend._backendLog [93]: [backend] but WITHOUT ANY WARRANTY; without even the implied warranty of
    2017-10-21 15:29:43,398 - DEBUG - UM.Backend.Backend._backendLog [93]: [backend] MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
    2017-10-21 15:29:43,400 - DEBUG - UM.Backend.Backend._backendLog [93]: [backend] GNU Affero General Public License for more details.
    2017-10-21 15:29:43,403 - DEBUG - UM.Backend.Backend._backendLog [93]: [backend]
    2017-10-21 15:29:43,405 - DEBUG - UM.Backend.Backend._logSocketState [178]: Socket state changed to Connected
    2017-10-21 15:29:43,408 - DEBUG - UM.Backend.Backend._backendLog [93]: [backend] You should have received a copy of the GNU Affero General Public License
    2017-10-21 15:29:43,411 - DEBUG - UM.Backend.Backend._backendLog [93]: [backend] along with this program.  If not, see .
    2017-10-21 15:29:43,412 - DEBUG - UM.Backend.Backend._onSocketStateChanged [168]: Backend connected on port 49674
    2017-10-21 15:29:53,301 - DEBUG - AutoSave.AutoSave._onTimeout [48]: Autosaving preferences, instances and profiles
    2017-10-21 15:29:54,590 - DEBUG - UM.Settings.ContainerRegistry.load [228]: Loading data into container registry took 11.059632539749146 seconds
    2017-10-21 15:29:55,240 - DEBUG - UM.Controller.setActiveView [84]: Setting active view to SolidView
    2017-10-21 15:29:57,054 - DEBUG - UM.Qt.Bindings.Theme.load [163]: Loading theme file: C:\Program Files\Cura 3.0\resources\themes\cura-light\theme.json
    2017-10-21 15:29:57,116 - DEBUG - UM.Qt.Bindings.Theme.load [231]: Loaded theme C:\Program Files\Cura 3.0\resources\themes\cura-light
    2017-10-21 15:29:57,287 - WARNING - cura.Settings.ContainerManager.getContainerMetaDataEntry [184]: Could not get metadata of container  because it was not found.
    2017-10-21 15:29:57,348 - DEBUG - UM.Controller.setActiveView [84]: Setting active view to SolidView
    2017-10-21 15:29:58,145 - WARNING - UM.Qt.Bindings.Theme.getIcon [109]: No icon tool_icon.svg defined in Theme
    2017-10-21 15:29:58,318 - DEBUG - OctoPrintPlugin.DiscoverOctoPrintAction._createAdditionalComponentsView [218]: Creating additional ui components for OctoPrint-connected printers.
    2017-10-21 15:29:58,343 - DEBUG - UM3NetworkPrinting.DiscoverUM3Action._createAdditionalComponentsView [138]: Creating additional ui components for UM3.
    2017-10-21 15:29:58,395 - DEBUG - UM3NetworkPrinting.DiscoverUM3Action.startDiscovery [38]: Starting printer discovery.
    2017-10-21 15:29:58,742 - DEBUG - UM.Qt.QtRenderer._initialize [172]: Support for Vertex Array Objects: True
    2017-10-21 15:29:58,756 - DEBUG - UM.View.GL.OpenGL.__init__ [85]: Initialized OpenGL subsystems.
    2017-10-21 15:29:58,759 - DEBUG - UM.View.GL.OpenGL.__init__ [86]: OpenGL Version:  2.1.0 - Build 8.15.10.2622
    2017-10-21 15:29:58,762 - DEBUG - UM.View.GL.OpenGL.__init__ [87]: OpenGL Vendor:   Intel
    2017-10-21 15:29:58,764 - DEBUG - UM.View.GL.OpenGL.__init__ [88]: OpenGL Renderer: Intel(R) HD Graphics
    2017-10-21 15:29:58,767 - DEBUG - UM.View.GL.ShaderProgram.load [55]: Loading shader file [C:\Program Files\Cura 3.0\resources\shaders\default.shader]...
    2017-10-21 15:29:58,777 - DEBUG - UM.View.GL.ShaderProgram.load [55]: Loading shader file [C:\Program Files\Cura 3.0\resources\shaders\selection.shader]...
    2017-10-21 15:29:58,786 - DEBUG - UM.View.GL.ShaderProgram.load [55]: Loading shader file [C:\Program Files\Cura 3.0\resources\shaders\default.shader]...
    2017-10-21 15:29:58,796 - DEBUG - UM.View.GL.ShaderProgram.load [55]: Loading shader file [C:\Program Files\Cura 3.0\resources\shaders\composite.shader]...
    2017-10-21 15:29:58,810 - DEBUG - UM.View.GL.ShaderProgram.load [55]: Loading shader file [C:\Program Files\Cura 3.0\resources\shaders\overhang.shader]...
    2017-10-21 15:29:58,826 - DEBUG - UM.View.GL.ShaderProgram.load [55]: Loading shader file [C:\Program Files\Cura 3.0\resources\shaders\striped.shader]...
    2017-10-21 15:29:58,844 - DEBUG - UM.View.GL.ShaderProgram.load [55]: Loading shader file [C:\Program Files\Cura 3.0\resources\shaders\platform.shader]...
    2017-10-21 15:30:01,258 - INFO - cura.Settings.GlobalStack.addExtruder [81]: Extruder[ultimaker3_extruder_left #2] added to [ultimaker 3] at position [0]
    2017-10-21 15:30:01,336 - INFO - cura.Settings.GlobalStack.addExtruder [81]: Extruder[ultimaker3_extruder_right #2] added to [ultimaker 3] at position [1]
    2017-10-21 15:30:01,887 - WARNING - UM.Qt.Bindings.Theme.getIcon [109]: No icon tool_icon.svg defined in Theme
    2017-10-21 15:30:01,890 - WARNING - UM.Qt.Bindings.Theme.getIcon [109]: No icon tool_icon.svg defined in Theme
    2017-10-21 15:30:04,547 - DEBUG - UM3NetworkPrinting.DiscoverUM3Action.reset [46]: Reset the list of found printers.
    2017-10-21 15:30:05,668 - DEBUG - UM.View.GL.ShaderProgram.load [55]: Loading shader file [C:\Program Files\Cura 3.0\resources\shaders\default.shader]...
    2017-10-21 15:30:05,678 - DEBUG - UM.View.GL.ShaderProgram.load [55]: Loading shader file [C:\Program Files\Cura 3.0\resources\shaders\grid.shader]...
    Same thing with me
    To delete the entire AppData folder would mean I will lose literally hundreds of filament details and several printer data so not a realistic option (did it to install 2.7 but won't do it again had to back in all that data)
    This is a KNOWN situation since 2.5 why can't we get it fixed over the long hail but how about a fix so at least we can give 3.0 a try
    Thanks
    Dr D
    Thanks in advance.
    We all got the message from Norton it is because there are not enough downloads to make it trustworthy give it another week or so and it will work out fine
    I just told Norton to allow it but I understand why you can't if your network is secure and you lack permission to allow otherwise blocked files
    NOTHING Ultimaker can do it just needs volume as the 3D industry is so small and we don't download things enough
    Dr D
    Hi
    Appdata is a hidden folder under C:\Users\[user]\ directory. When you unhide that, you'll find the Cura folders under: C:\Users\[user]\Appdata\Local\Cura and C:\Users\[user]\Appdata\Roaming.
    It's a known issue that was fixed but unfortunately was not included in 3.0.3.
    As workaround, fieldOfView has provided a file that you can replace C:\Program Files\Cura 3.0\resources\shaders\grid.shader with. Link to the shader file that will solve your issue.
    Check out: https://github.com/Ultimaker/Cura/issues/2644
    Sounds like you have something similar as the user above ^. Can you check your logs if it's the same error you're getting? If it is, you can replace the shader file as well.
    My log:
    Hi saymon, check my reply above. The link provided is a workaround to this issue.
    Thanks!
