On 12/27/2017 at 5:41 PM, gr5 said:Look into the "neosanding" feature.
Thanks for the suggestion. Is this the same as the "Enable ironing" feature under Shell settings? I've tried with that ON.
Surprisingly, my best results so far are with ironing OFF, but setting:
- Wall Thickness 0.8 mm (with 0.4 mm Nozzle)
- Top Surface Skin Layers 1
- Top Surface Skin Pattern Concentric
gr5 2,210
Look into the "neosanding" feature (I think that's what it is called in cura or maybe it's called smooth top surface?) Ideally you want to do a second pass on the same layer as you just finished but just going in the alternate direction (90 degress from infill below and also you want it to reach into the shell a bit and Neotko himself also recommends a tiny tiny bit of extrusion while neosanding - something like 10% extrusion I think.
Neotko does this with S3D which gives you slightly more control (like the ability to extrude during sanding a tiny amount).
