kmanstudios 1,120
10 minutes ago, gr5 said:To make this clearer - the A2 area should show the yellow filament coming from the TOP of the spool.
I put it on the bottom because that is the way it would feed, at least by my thinking, but it can still get twisted. That is what took me so long to figure out what happened. I have always fed from the bottom as the illustration shows, but the coiling can be a problem if one is not careful when pulling it out or it will corkscrew.
I think that maybe adding a (3) series to the mix would be good to illustrate your point. If anything, just to show that it would be wrong to load it that way for a feed going up like this.
kmanstudios 1,120
Figures A1 and B1 show that feeding the filament curvature in the direction of the curvature of the bowden tube helps it feed because it does not want to bend against the bowden tube.
Figures A2 and B2 demonstrate that if the curvature is not aligned with the bowden tube, it will tend to bend against the curve of the bowden tube and increase friction.
Sorry that I did not make that clear, and may still not have. I have had about 2 hours of sleep since yesterday and the ol' clockworks in this dusty belfry may be freezing up a bit. I do hope that this is more clear.
If not, please ask again. I aim to help and if I am not clear, then it ain't happening.
gr5 2,333
