Thanks for your reply.
The commands I'm talking about is part of the gcode which is generated previous to my start gcode:
;FLAVOR:RepRap
;TIME:906
;Filament used: 0.566464m
;Layer height: 0.2
;Generated with Cura_SteamEngine 3.1.0
T0
M190 S65
M104 S210
M109 S210
M82 ; absolute extrusion mode
;StartGCode defined for Marlin 1.1.6 DB version 20171210
G21 ;metric values
G90 ;absolute positioning
M82 ;set extruder to absolute mode
M107 ;start with the fan off
G28 X Y Z ;move XYZ to min endstops
G1 F1800 ;set speed to 50mm/s
G1 X0 Y0 ;move to A8 heatbed-zero
G1 Z15 F3600 ;move extruder up
G1 F600 E3 ;extrude 3mm of feed stock
M117 Drucke...
I'm looking for an idea to change the sequence of M190, M104 and M109.
gr5 2,210
Which version of cura? For which printer? This sounds like a custom printer so you can mess with the "start" gcodes in the machine settings. You can change these to whatever you want and cura will remember.
