>My plan is to use a 0.6 3d solex steel nozzle for printing woodfill filament.
>So I don't need to change anything else?
Right. 0.6 and 0.4 aren't all that different. You shouldn't have to change temperature or speed or layer height or anything else. Just change the line width. I prefer to do 0.6mm line width for a 0.6mm nozzle but it will work just fine if you do a 0.55mm line width. Maybe even a little better result depending what you care about. The 0.6 might be slightly more dimensionally accurate. You can probably push up the speed more if .55mm line width. maybe.
1
gr5 1,512
Just use the AA 0.4 profile - even when I use an AA 0.8 core I still use the AA 0.4 profile as I find it to be better. At least for me.
Then change line width to your nozzle width (in your case set "line width" to 0.6mm).
