QuoteThe increase in diameter happens to me also but it's not a problem for me. I can still print just fine. Is your "third fan" working? The one in the door of the UM3 print head?
Yes, it is working.
I suspect the diameter because when I remove the boden tube, the filament gets stuck precisely when I try to push in the thicker part.
I'll try with the provided second AA core. Thanks for the tip. Launching a print and getting back to you.
gr5 1,872
You should have gotten a second AA core. Have you tried that to see if there is something wrong with your core?
