Generally I'm more concerned with quality not speed or time in my projects. In your case perhaps just the reduction in the Print Acceleration, Travel Acceleration, and Jerk settings will suffice. Please post the results of your success / failures with the changes.
I suppose the position of the two cores can be switched so long as Cura knows which core is each location and the settings for each are correct. I'd defer to Erin fbrc8-erin for the final verdict on that question.
1
XYZDesignPro 70
I personally find the default speed settings in Cura for the UM3 are all too violent for my liking. I slow all of the settings down for both extruders. It may take marginally longer to complete a job, but the machine isn't jerking and clunking about so violently.
Any particular reason why you are using the BB core in the 1 position and the AA core in the 2 position?
fbrc8-erin 316
I haven't had issues with the default PVA settings like this.
It looks like your magnets are still in place where they should be in the front bracket, so that's good.
From the looks of things, if I was going to guess, I think the bracket probably opened first, and then it would have hit the existing print, causing the bed to dislodge. (Rather than the bed dislodging and then the bracket opening.)
Is it possible your bracket is bent to more than 90 degrees? The metal is pretty soft and it won't hold a good connection if it's bent to more than 90 degrees. Quick video on fixing the bracke:
nyb 1
Thanks for the tip, I will try slowing all speed settings down by 50% then.
Should BB and AA cores be inverted? I have this configuration because the PVA spool is in a custom box with controlled humidity, which is on the left with respect to the printer's front.
