Does USB printing work for anyone? Ever since going to 3.4 beta, I start a print, the bed and head heat up but the status sits at 1% and the nozzle never moves from the initial position. A home doesn't happen... nothing. If I copy the gcode to the SD card and put it in the printer, it prints.
I am using 'Marlin' as the gcode type and the printer is a Wanhao Duplicator 9 which works fine printing via USB with 3.3.1.
EDIT: I reinstalled 3.3.1 and it printed via USB just fine.
The only odd thing is that when I started 3.4 beta, it said my settings were corrupt or invalid (something like that) so I had to go over the settings 1 at a time to set it up again as I chose to reset the settings in 3.4. I wonder if the reason for this corrupt thing is that i am using some plugins (Scalable Extra prime). Maybe those settings were not known or something as the plugin is not installed by default with 3.4 when you first run it. This is likely a separate issue but worth noting.
Edited by Adam324
Top Posters In This Topic
13
11
7
6
Popular Days
Jun 5
16
Jun 7
12
Jun 8
8
Jun 6
6
ctbeke 13 posts
AbeFM 11 posts
ahoeben 7 posts
rebekah_harper 6 posts
Popular Days
Jun 5 2018
Jun 7 2018
Jun 8 2018
Jun 6 2018
Popular Posts
SandervG
Ultimaker Cura 3.4 | Beta It’s time for the next step in the evolution of Ultimaker Cura. We’re excited to share Ultimaker Cura 3.4 Beta with you! This new version holds a lot of improvemen
burtoogle
And whilst we're blowing our own trumpets ?, there's a new Travel setting called "Max Comb Distance With No Retract". When set to a non-zero value, combing travel moves that are longer than that dista
thopiekar
Always a pleasure, @SandervG and the rest of the world! ?
Posted Images
LePaul 321
At work now so I won't be able to download/test it until evening (East Coast United States here)....but will check it out.
