Is there a 2.85 option? Or I would have to make a UM3 hotend to make that work? I still use 2.85mm filament for all my other printers currently.
38 minutes ago, 3dprntz said:Is there a 2.85 option? Or I would have to make a UM3 hotend to make that work? I still use 2.85mm filament for all my other printers currently.
You could drill out the top coupler holder to let a 2.85m filament through and find a thin enough ptfe tube that fits in the pipe but is also 3mm ID. Someone mentioned that they modified the parts earlier in this thread for 2.85mm.
On 1/31/2024 at 8:53 PM, ansonl said:
Sand down the threads at the tip of the moving heater block screw so that the top portion of the screw moves freely in the hole in the bottom plate.
If it doesn't move freely enough, you can drill out the threads in the threaded hole in the bottom plate that the moving heater block screw would go into.
Your setup looks good!
Ahh, thanks! Why didn't I think of thank haha.
On 2/1/2024 at 1:03 PM, ansonl said:You could drill out the top coupler holder to let a 2.85m filament through and find a thin enough ptfe tube that fits in the pipe but is also 3mm ID. Someone mentioned that they modified the parts earlier in this thread for 2.85mm.
You could install the UM3 toolhead- 😊 it works great
22 hours ago, Garufa said:You could install the UM3 toolhead- 😊 it works great
Wouldn't be a bad idea. Has the print head part become cheaper? And does the bed leveling works with the included capacitor?
27 minutes ago, 3dprntz said:What linear bearings are you using?
Drylin bearings, didn't buy them myself they were already on the printer.
On 2/6/2024 at 5:36 PM, 3dprntz said:Wouldn't be a bad idea. Has the print head part become cheaper? And does the bed leveling works with the included capacitor?
I have not tested the bed leveling with it, I understand that additional hardware is needed.
On 2/5/2024 at 6:33 PM, Garufa said:You could install the UM3 toolhead- 😊 it works great
Files to 3D print the toolhead are in GitHub - one piece is best in metal or high heat resistant material
- 1
1 hour ago, Garufa said:Files to 3D print the toolhead are in GitHub - one piece is best in metal or high heat resistant material
I printed them in resin to test the concept. I think I used a temp resistant ABS like resin. The lever was too sticky or had too much friction.
4 hours ago, LouDFPV said:Drylin bearings, didn't buy them myself they were already on the printer.
Do you know if they are igor drylin bearings and what are you option on them? Smooth?
23 hours ago, Garufa said:
Could you provide a link? I am having a hard time finding the page. I did find this but it appears that it is off the shelves or not sold anymore. 3D Printer Accessories ul...-Taobao.com
Edited by 3dprntz2 hours ago, 3dprntz said:Could you provide a link? I am having a hard time finding the page. I did find this but it appears that it is off the shelves or not sold anymore. 3D Printer Accessories ul...-Taobao.com
https://www.bhiner.com/Search?skey=UM2.5 25100
https://www.bhiner.com/taobao-agent/646573803386
6 minutes ago, Garufa said:
6 minutes ago, Garufa said:https://www.bhiner.com/Search?skey=UM2.5 25100
https://www.bhiner.com/sellerStore?seller=尚电明华&offset=1
the last one takes you to the seller's store - look for UM2.5 and UM3 toolhead parts.
4 hours ago, Garufa said:
Awesome! This one is the UM3 head board? 3D printer accessories DIY suitable for UM machine upgrade extruder adapter driver circuit board NO.2012 | Taobao Agent Bhiner (www-bhiner-com.translate.goog). I don't know how much you can understand, but the previous one you sent for the UM2.5 is just the board or the whole print head? Guess this one is confusing since it shows the partial head instead of the whole with all the fans. Have you worked through this agent website before?
On 2/11/2024 at 8:13 AM, Garufa said:
Wow, really cool that they seem to have created a PCB adapter for the UM2 electronics to be linked to the UM3 printhead and the nozzle cartridge. I wish that was available a few years ago. I can't tell if the nozzle cartridges are usable with the UM3 or if they are custom made to only be used with their UM2.5 custom adapter from the pictures.
I took some pictures of the 24V 35W heater cartridges that I had previously made for the DXU. The heaters have strain relief at the 90 degree bend and the unheated rear portion is slightly longer to avoid the heater wires touching the back of the hotend cooling fan. The strain relief help reduce the wear and tear that is normally put on the heater wires that you would previously bend to 90 degrees to insert the cartridge into the Olsson style heat block. It's mainly for the second extruder that encounters the up and down movement but I've used it on both sides myself.
I have a couple of spares cartridges that I can send (DM me) for a fee if anyone else is doing the DXU build in the future.
15 hours ago, 3dprntz said:Awesome! This one is the UM3 head board? 3D printer accessories DIY suitable for UM machine upgrade extruder adapter driver circuit board NO.2012 | Taobao Agent Bhiner (www-bhiner-com.translate.goog). I don't know how much you can understand, but the previous one you sent for the UM2.5 is just the board or the whole print head? Guess this one is confusing since it shows the partial head instead of the whole with all the fans. Have you worked through this agent website before?
Yes I have purchased the PCBs for the toolhead and nozzles and no they are not compatible with UM3 PCBs. At the back of the nozzle and toolhead are 4 contact points instead of 5 and no circuits for LED or sensors- you can use the UM3 parts but replace the PCBs and adapt if you want to use 1.75 mm filament.
The clone um2.5 print cartridge fits 1.75mm as shipped? And the real um3 cartridge is for 2.85mm?
mentions that the heat throat and pcb needs to be programmed to work in this one.
Edited by 3dprntz2 hours ago, 3dprntz said:mentions that the heat throat and pcb needs to be programmed to work in this one.
Those are for the original UM3 - compare the PCB boards with the UM2.5 to see the differences
8 minutes ago, Garufa said:Those are for the original UM3 - compare the PCB boards with the UM2.5 to see the differences
or modify the PCB as DIY see picture below form another forum
- 1
Top Posters In This Topic
53
44
33
19
Popular Days
Apr 3
8
Feb 9
7
Feb 13
7
Sep 13
6
Garufa 53 posts
yyh1002 44 posts
ansonl 33 posts
LouDFPV 19 posts
Popular Days
Apr 3 2019
Feb 9 2024
Feb 13 2024
Sep 13 2020
Popular Posts
yyh1002
Hey guys, I would like to share a lever action dual extrusion solution I came up with for Ultimaker 2+. The approach is based on the great effort everyone put into Mark2 and Ultimaker
yyh1002
Some recent timelapse and photos of DXU.
yyh1002
Congrats on being the first to make it from overseas!(except for me;))
Posted Images
ansonl 19
1.75mm
