Dim3nsioneer 557
If you print it on the Ultimaker adhesion sheets with the printer front closed adhesion will not fail. You might want to consider to print more than one at once as the bed has to heat up to 107 degC. That takes quite a while (about 15 min).
1
Brulti 177
Actually, since printing 10 parts together will not save you time compared to printing them one by one, I would advise you to print them one by one. PC requires glue, brim and an enclosure, it will be easier to print them one by one, and you will not loose the whole batch if there's a failure at some point. It's better to have to restart one part that failed two hours into printing than ten that failed fifteen hours into printing.
Fulv 1
Hi Thank you for the advise. :)
