DidierKlein 729
I don't think it's a good idea to use S3D with the S5. (I know that for the UM3 for example some stuff related to dual extrusion is handled better by Cura).
Anyway, obviously some things in the gcode are written in order to detect the profile used and printer etc... maybe try to generate a gcode with Cura and compare the information? (Most probably in the first few lines)
1
Smithy 1,131
Hi
a good start is to use the UM3 profile and then adjust the dimensions of the build plate if you really want to use S3D.
simon-ber 0
Hi Smithy,
Thanks. I have already tried the UM3 and um3 extended, it doesent work,
Do you have an idea?
