A skirt still requires room on the buildplate. Go into the Custom settings, and set Build Plate adhesion to "None". If you don't use the second extruder in this print, disable that extruder. There are a couple of other settings that also affect the grey shaded area around the build volume.
1
Beanland 1
Have you selected build plate adhesion with a brim? If so deselect as this will increase the o/a size of your print.
Saij 1
No. I only have a skirt.
