It's not a general software bug, since that would never have cleared QA on our side. For me it takes less than 2 seconds for all settings to load on boot and drop down menus open in 100 ms or something like that.
None of this happened when I first started using Cura on this computer. Could something in my computer be limiting its performance?
Actually now its back to working correctly. Its lightning fast. The only thing I have changed is my wifi connection. I changed to a network that works better. Could this have been the cause?
Hm, maybe my maschines are just crappy. I will take a look at the network settings also.
I think I figured it out. I was looking at some forums about internet slowing down cura, and apparently cura tries to connect to web printer servers like octoprint. I am on a large wireless network because I am a college student using dorm wifi, so Cura was trying to find all the wireless printers on the large server (there is none), thus slowing it down. I just went to the plugins and deleted the one that has to do with wireless printers. C:\Program Files\Ultimaker Cura 4.2\plugins and delete the one called UM3NetworkPrinting. That instantly fixed the problem, and I dont use wireless printers. If I ever do, I'll just reinstall cura or something to get all the proper network plugins back.
4
It's not trying to connect to all of them, but it is listening to broadcasting messages (It's a fairly important difference. The first is actively contacting every single IP to check if it's a printer, the second is waiting for someone to shout "IM A PRINTER").
Alternatively, you can also just disable the plugin in the marketplace. You can do this in the installed tab.
I turned this plugin off too and it really makes a difference, much better now.
I am also on a large network (company).
- 2 months later...
On 9/2/2019 at 9:00 AM, nallath said:It's not a general software bug, since that would never have cleared QA on our side. For me it takes less than 2 seconds for all settings to load on boot and drop down menus open in 100 ms or something like that.
Well, then you need a better QA process 🤷♂️ I've now tried Cura 4.2, 4.3, and 4.4. All clean first installs
None are even remotely usable on a Ryzen 2700x with 32GB with Ram.
None were even showing up anything, even though appearing on task manager. Out of interest I didn't "kill" 4.3 after 5 minutes.
The splash screen appeared after.... 20 minutes. After that the GUI appeared in just 15 or something 😅
Then I found this thread and deleted the plugin above also, no change (I'm home by the way)
So, there is clearly something going on here.
After many hours of trying and cleaning the registry etc - still nothing. Deleted filters, added to the firewall, compatibility, run as admin, ....
I have tried on another PC and it works 100% - same windows version. Something is definitely up.
(log attached - stderr and stdout are 0Kb)
I've also tried 3.3 - worked 100%.
Well, there is your problem. Ryzen has had a slew of bad driver updates. Depending on the behavior of the program, it breaks or slows down dramatically. Apart from re-writing the behavior of the entire program, there is little we can do about it, since it's Ryzen that is at fault here.
- 4 weeks later...
Does the same bandwidth hogging happen if you go to the Installed tab of the Marketplace, unselect the Ultimaker Network Connection and restart Cura?
- 2 weeks later...
On 11/27/2019 at 4:34 AM, nallath said:Well, there is your problem. Ryzen has had a slew of bad driver updates. Depending on the behavior of the program, it breaks or slows down dramatically. Apart from re-writing the behavior of the entire program, there is little we can do about it, since it's Ryzen that is at fault here.
That is factually incorrect and it makes me worry about the quality of your programmers 😞 Deleting 1 plugin makes your program load approximately 100x faster, and it has nothing to do with Ryzen. If it did, there would be literally hundreds of developers with the same problems, but they aren't any. Cura runs insanely slow compared to every other slicer program out there. Your UI feels like it's being displayed through molasses, on a 2000$ computer, which is insane. And I can bet cash money your response will be, oh it runs fine for us, it must be a problem on your end. And yet every other program has 0 issues. But yeah keep blaming the processor.
Similar problem here. Recently started playing around with Cura 4.3 and updated today to 4.4. GUI of both version is terribly slow. Switching between extruder 1 and 2 tab e.g. about 10s and drop down menues also take several seconds to open. Can not tell if it has been like this from the beginning, though. Turned off UM3 Network Printing plugin but doesn't improve.
Also had to change to Windows 8 compatibility mode to be able to start Cura.
my config:
Windows 10 Pro on a Lenovo V330
Intel i5-8250, 8GB Ram, 512GB SSD
Intel UHD Graphics 620
The zeroconf issue with the networking plugin has been improved a lot as we merged our fixes with the upstream library. The changing of tabs should also be a bit faster for 4.5
13 hours ago, AgentPothead said:That is factually incorrect and it makes me worry about the quality of your programmers 😞 Deleting 1 plugin makes your program load approximately 100x faster, and it has nothing to do with Ryzen. If it did, there would be literally hundreds of developers with the same problems, but they aren't any. Cura runs insanely slow compared to every other slicer program out there. Your UI feels like it's being displayed through molasses, on a 2000$ computer, which is insane. And I can bet cash money your response will be, oh it runs fine for us, it must be a problem on your end. And yet every other program has 0 issues. But yeah keep blaming the processor.
Not all of the issues have to to with the Ryzen, but a fair part of them do. We're also far from the only software that is suffering from the Ryzen issues (so there *are* literally hundreds of developers with the same problem)
19 minutes ago, nallath said:Not all of the issues have to to with the Ryzen, but a fair part of them do. We're also far from the only software that is suffering from the Ryzen issues (so there *are* literally hundreds of developers with the same problem)
6 hours ago, AgentPothead said:
https://forums.tomshardware.com/threads/ryzen-27700x-black-screen-issue.3393849/
https://www.reddit.com/r/AMDHelp/comments/804fv7/ryzen_7_random_black_screen/
https://community.amd.com/thread/231672
Want me to google a few more, or is this enough citation?
On 9/2/2019 at 10:00 AM, nallath said:It's not a general software bug, since that would never have cleared QA on our side. For me it takes less than 2 seconds for all settings to load on boot and drop down menus open in 100 ms or something like that.
Wow, that is a bold statement. I use Cura 4 on two different Mac computers. It taks up to 30 seconds just to expand some configuration alternatives in the Print Settings menu. And almost never under 5 seconds. I'm tearing my hair out in frustration. Fortunately I have only on of my printers being a Ultimaker, so for all the other ones I can use Slicer. But for the S5, I have to use Cura and it is a really, really, really slow and bad piece of software. I paid €7000 for that machine, due to Cura I hate using it.
Any Cura 4.x.x is also very painfully slow on my workstation, but I also have an install of 3.4.1 on the same machine and it runs great. The only way I can get the Cura 4 to boot at all is running Windows 8 compatibility mode so I wonder if this has something to do with it?
Windows 10 64 bit
i7-6700
16GB RAM
Intel HD graphics 530
Edited by Travis7s
I think it's a definition problem. A general problem is something that occurs during all situations. That was also what my statement was about. If it would be so slow for all computers, our QA department would definitely have found it. Since that didn't happen, it's not a general problem (it's still a problem, but if we can't reproduce it, it's a complete nightmare to actually fix it).
That being said, I have made a bunch of speed improvements the past few days. I can't say if those solve the issues (because I don't have them), but it should make things faster in general.
56 minutes ago, nallath said:I think it's a definition problem. A general problem is something that occurs during all situations. That was also what my statement was about.
Thanks for the reply, and sorry if I sounded harsh. I'm just very frustrated, this program I am so dependent on, eating up my workdays.
I think it is a problem on many Macs. Some more info, if it can help you:
- I have one MacBook Pro 2015 (i5, 8GB, Inten Iris, 512GB SSD) and one MacBook Air 2013 (i7, 8GB, Intel gfx, 512GB SSD). Problem is the same on both.
- Both machines works very fast in Fusion 360 on large, complex models
- MacOS 10.14.6
- The GUI is fast when no model is loaded, so it seems to me that the GUI uses 3D rendering resources. The more complex model loaded, the slower the GUI is, down to 30 seconds respons time per click.
Then I have some good news for you, as that's exactly the bit I've improved (although it was nowhere near as dramatic as you have it). It used to re-render the entire scene when any GUI element needed an update and now it's a fair bit smarter about what it needs to update.
You could also try to force the compatibility mode. You can do this by going into preferences and select "force Layer view compatibility mode"
27
21
17
6
Popular Days
Jan 3
12
Jan 2
6
Sep 2
5
Jan 20
5
GAD 27 posts
nallath 21 posts
ahoeben 17 posts
Kenobinai 6 posts
Popular Days
Jan 3 2020
Jan 2 2020
Sep 2 2019
Jan 20 2020
Popular Posts
Nerfstrike
nallath
In 4.5 we also switch to a much more extensive crash logging system, so let's hope it gives us what we need 🙂
GAD
This afternoon (I was out all day) Cura is slow and unusable. I'm going to re-test having the Networking plugin disabled because when I tested that Cura had locked up entirely and it's never done that
Posted Images
Cymon 5
I experience the same when opening a drop down menu in the advanced print settings. The settings appear slowly one after another. Tried it on a few different machines (Workstations and laptops) and there is no difference. So maybe it's a general software bug.
