PVA.......well.....
Cut a long story short, we've stopped using it. We now use "breakaway" with AA0.4.
Story:
The last straw was when the PVA broken and got stuck in the feed channels underneath the machine (just after the material bay loading points). The amount of times the material has broken and jammed inside the bowden tubes is unreal, as it feeds you can hear the cracking sounds of the material breaking.
Storage has always been within a sealed bag along with a bag of "Silica Gel", prior to using, we warm the material inside the machine, by laying it onto the print bed for about 1 hour @ 60°C..
It just given us a lot of problems and wastes a lot of time, for very little benefit.
What we have noticed using "breakaway" is that the parts are a little more accurate......
Edited by Carbon
gr5 2,330
I don't find it to be brittle. Maybe you dried it a little too much. Also I don't have to warm it up before use.
But I keep it in a 2 gallon zip lock with a LOT of dessicant. And I recharge the dessicant about once per month. Maybe 1/2 cup of dessicant.
I usually get impatient and keep poking at the part - I put it under water in warm water and try to pull some of the PVA off right away then I walk away and come back several times removing more and more PVA. When the final layer is pretty thin - just a few mm thick I usually leave it overnight. I've never had to wait 24 hours but 4 hours is definitely not enough either.
I change the water a few times in the first hour. The water tends to be room temp for most of the time. It's only warmer than that when I first fill the bucket and each time I think of it, I change out the water.
