GregValiant 1,305
Hello @JvH
I don't know the Ultimaker printers but I do know a bit about automation. My first question would be: Who (or what) removed the previous part from the build-plate, and why didn't they reset the printer when they did?
@Smithy, If there is a lockout on the S5 that must be "reset" in order to start a print (and it sounds like there is), and if that "reset" signal is blocked from being accepted from a remote source, then it might be possible to have a custom alteration of the firmware to allow the "reset" signal from both a remote source and from the local source (the existing function on the printer). I don't know if "removing the block" is the right term or if in fact it might be wildly difficult to do.
I seem to recall from reading around here that @tinkergnome and @ahoeben have worked with the Ultimaker firmware. There must also be some folk at Ultimaker capable of addressing the issue. Maybe it's something that could be contracted?
It would seem to me that in the case of a production situation that includes an automated system for removing a completed build plate and replacing it with an empty one, that system would require a remote printer reset before the next print could start(?). Either that, or the end-of-arm-tool (or pick-and-place) would need to push a button (or something) to perform a manual reset? It would seem to be much easier to send a remote command to let the system know "build plate is ready".
In the case of the OP - JvH sitting at his computer at home could check a camera feed to insure the build plate is clear, send the reset if it is, and then start his print or free up the queue.
I don't know how much of that is relevant or doable. Many things are possible if you throw enough money at them.
Maybe I'm just showing off my ignorance on a lovely morning. If that is the case then I apologize for wasting everyone's time.
Smithy 1,144
No it is not possible. It is more like a security feature that nobody can start a new print until the object is removed from the bed to avoid damage to the printer. I understand your use case, but I don't think there will be an update to confirm remotely.
