The reason is probably the connector part (collet) in the feeder, where you put the Bowden tube in. There are very small blades which should grab into the Bowden tube to avoid that it can slip out. In your case it seems that these blades don't grad deep enough into your Bowden tube and that's the reason why it slips out during printing.
Contact your reseller to get a new collet, it is cheap and solves your problem.
In the meantime you can try to cut of 3mm of the Bowden tube that the blades can grad into fresh material.
1
And please don't mention users in every post just to get a faster response. We are also fast at replying and it is rude to mention masses of users. You will only achieve the opposite, so please do not do that in the future. Thank you.
1
sure smithy will take care in future, and thank you for the response
actually this Monday (Today) we have sales people coming from all over the world, they come to visit the plant yearly once, and during their visit they also visit our prototype building shop wherein they would see me printing some 3D prints.
that's the reason I was rushing to get answers from Ultimaker experts in last week. I just wanted everything to function normal during their visit. and hopefully it does happen
Thanks
Understand, good luck! 🙂
UlrichC-DE 107
Printing with PLA for a demonstration is a good thing.
Ultimaker ABS and CPE would also be suitable for a safe demonstration. Both filaments have the property that they adhere well to the plate.
Demonstration always sounds like a 100% solution. Hence the thought.
Practically, you can also print temporarily with just the second printhead as an alternative.
I and probably the others answer posts on occasion and in context.
The exchange helps me keep my own production running and improve. I can recommend, because that saves time.
Wish you good luck
Paramesh 3
also changed the Print head, but no change
