I also noticed the new "pause" feature when printing.
I like that now for the UM2 - unlike pause in UM1 - the head moves up and out of the way before pausing.
Some questions/issues on pause:
1) When pausing it seems it takes a while (buffered?) before it actually pauses. Is there a way to calculate how long it will take? Is is a specific number of line segments/gcode lines?
2) I cannot find a way to change filament during a pause. I think that most people would use pause to change filament. Of course it could be useful for other things as well (inserting objects into a print etc) but I really think it needs to be possible to change the filament.
Feasible to implement? The Replicator 2 has this feature I think and it would be nice if we had it too.
39
28
17
14
Popular Days
Feb 19
27
Feb 21
21
Feb 24
14
Feb 20
13
Daid 39 posts
Dim3nsioneer 28 posts
drayson 17 posts
maartenw 14 posts
Popular Days
Feb 19 2014
Feb 21 2014
Feb 24 2014
Feb 20 2014
gadgetfreak 7
I just downloaded the RC3 and upgraded a UM2 with the firmware (which the printer says is 14.02.1).
After running a very short print (only 0.1mm layer), at the end the print stopped and then the timer counter counted down for a few second...and then it started displaying 6 hours. Still the head was still and not moving, also still heated bed and hotend heated.
I waited only a minute or so before I aborted.
Not sure it matters, but this was a print with Initial layer thickness 0.1mm and I had cut off object bottom enabled as well.
I.e. with the cut-off it was 0.1mm high, otherwise 0.2mm high.
I'm guessing this is a firmware bug?
Did not try this print with previous/other firmwares though.
