Dim3nsioneer 556
First, Daid, thanks for asking... :-P
The layer view / toolpath is important for me to check is slicing is done in the way I want it to have. This includes e.g.:
- accuracy of vertical walls (all layers well aligned?)
- thin walls: number of lines used (too thick?)
- infill spacing correct?
- combing lines visible?
- small details sliced properly?
- lines vertically aligned in a way which makes the print weak at some point?
Thus, it is important for me to be able to distinguish the individual lines. There is actually an effect on both of my Windows 8 machines that makes it impossible to get a resonable feeling for the lines:
Both graphics chips use the NVidia drivers, i.e. are quite common.
What I really, really miss in Cura layer view is a representation of the actual print speed. Therefore, I often use gcode.ws for checking individual layers. Having an idea how fast or slow a layer is printed is important to e.g. set the correct TweakAtZ-layer.
I'm also not completely happy with the way travels and retracts are displayed in Cura. These lines are too thin at the moment for my taste. Again, gcode.ws uses bullets for retraction which are well visible (but can be switched off if they cover something important).
Finally, I agree with Jonny for the layer selection. Less is sometimes more...
And really finally: I hope that the layer numbering of the GUI and in the gcode will be the same in Pink Unicorn.
@JonnyBischof: For 1., try Shift+Up or Shift+Down...
jonnybischof 60
Actually, I think the current mode is pretty good! Saying that something about it sucks is harsh...
Some thoughts:
1. Make it possible to step between single layers (currently there's only the slider. With high layer density, slider control sucks). Maybe just add "single step" buttons on top and bottom of the slider, like the standard windows explorer sliders.
2. Make it possible to view single layers only. Let's say I want to inspect a bridging layer closely, without having all the other layers below. Also, it should be possible to see and differentiate the actual lines. At the moment, infill looks just like a yellow face, you can't see where the lines actually go. Maybe make a checkbox where you can switch between "actual line thickness" and "thin line thickness".
3. In Layer view with the full model displayed (top layer selected), it's difficult to see anything because the lines have a zero "layer thickness". Wouldn't it look better if the lines were actually drawn as thick as the layers they represent?
4. Maybe play a bit with the contrast / color scheme.* I'd like to be able to use the layer view like repetier host's Gcode viewer, where you can see the "actual" surface that your model will have. There were some issues with uneven surfaces lately, where Repetier host showed that Cura generated a bad surface. If it were possible to see that directly in Cura - that would be great
* Maybe make "all" colors user selectable through the preferences dialog? Not just the model color?
/edit:
Looking forward to seeing what you come up with!
/edit2:
Not sure what you mean by "toolpath view" exactly. But it would be cool if you could "simulate" the printing process by actually drawing the lines like the printer does it. Some speed control would be necessary of course, and maybe an option to jump to a certain layer height.
I also forgot one thing:
Make a "translation" between layer number and build height. For example, don't only show "layer 100", but "layer 100: 10.2mm"
For technical stuff that needs exact measurements, it would be nice to be able to verify Z-dimensions in such an easy way.
