One thing I noticed with the thin hair stuff is: draft.
Last week I was printing at an event where they had a fanatic cooling system causing a cold draft. Could it be that too much cooling has something to do with this?
Want to see my fur?? :mrgreen:
This is a bust i printed yesterday with BioFilla Linen:
A lot of fur every where. It's very thin my guess is that it's thinner than real hair.
I will have a timelapse (tonight) of the print maybe it will show something?
I thought about it during the night (yes i sleep badly) here's my twisted theory on this:
Let's imagine that the nozzle puts some extra material at random places and that the fan blows on it creating a small hair.
It's so small that it would stay in glass transition due to the heated bed and the nozzle head.
So every time the fan blows on it, it grows a bit making it even more thin, thus more subject to the phenomenon
The fan theory is mine too i posted this a while ago
On curling, my experience this week shows me that the filament itself can be one of the causes. I was using Faberdashery gold and was getting lots of curling - to the point that I stopped and did an atomic pull. Today I spent 6 or 7 hours printing with their Arctic white and did not get a single curl. I was printing the same pieces in a different colour so used the same settings - except for extruder temp which was 5 degrees different
Funny I noticed the same with that gold filament last time I used it.
Lol I think we need a Curley alert thread somewhere.
Further results on the ongoing fur saga.
I currently print with Colorfabb PLA/PHA and CO-Polyester XT. (not at the same time of course :mrgreen: )
PLA/PHA: 0.1 layers, Speed 50, temp 200, bed 60 = Not a single hair
Swap to XT: 0.1 layers, Speed 50, temp 240, bed 70 = Fur everywhere.
No matter how clean or dirty my nozzle is XT makes fur and PLA don't. It must be either the material difference or as gr5 said the higher temperature. Over the last month I have probably swapped the material for at least 10 times and it just keeps happening.
I might contact Colorfabb and ask what they think.
I managed to catch the hairs printing on video, you might want to look in full screen
What i see is tiny strings of filaments that get carried by the nozzle and are then blown away by the fans. It looks like the nozzle is catching some tiny parts from the previous layer. The nozzle is getting quite dirty during the print.
Colorfabb Marine Blue PLA
Temp: 220°c
Layers: 0.2mm
speed: 50mm/s
Turning the fan down to 25% seems to solve this problem for me...
Edited by GuestI know this thread is super old but wanted to comment on it. I recently started having pretty bad stringing issues with most PLA filament that I hadn't had before. I tweaked lots of setting (retraction distance, fan speed, extrusion multiplier, Z lift, etc) and printed tests with very little change in quality. It dawned on me that most of my issues started when I switched to a hardened steel nozzle from E3D. I had always used a brass nozzle. Anyway, I switched back to a brass nozzle and quality with regards to stringing was improved. If you can see the picture, the ones on the left are all prints I did by altering previously mentioned settings to try to reduce stringing. The one on the right is after I put the brass nozzle back on. 0.4mm E3D nozzle, Prusa MK3S, 210/65, 1.5mm retraction, Z lift 0, retraction speed 60mm/s, 0.15mm ht, solutech and hatchbox pla. I'm not sure why, in my case, the hardened steel nozzle is more prone to this. It appears clean.
We call this kind of "fir" stringing. stringing is a little bit of nozzle leakage in a straight line between two points that the nozzle moves between.
"hair" is usually a strange phenomenon similar to cotton candy where extra thin hairs come out of "nowhere" and get blown around and find their way everywhere with no discernable pattern.
Anyway, thanks for this post, it confirms some things I knew - basically internal geometry of the nozzle is important. More expensive brass nozzles usually string less - usually they have a more gradual slope going from 4mm or 2mm I.D. down to the typical 0.4mm I.D. The length of the final channel is important also. If it's too short then the nozzle leaks more.
3dsolex.com "race" nozzles seem to string not-at-all as far as I can tell - even the 0.8mm nozzles because of their complicated internal geometry. disclaimer: I sell 3dsolex products in USA at my store: thegr5store.com so I am biased.
@gr5 do you find that hardened steel nozzles produce more stringing?
The one from 3dsolex does, yes, because it's 0.5mm and also because it has no internal structure. But every manufacturer of nozzles has a different internal structure with different length of the final 0.4mm tunnel.
More info in this video but this guy is sometimes amazingly stupid, but usually quite smart. He didn't notice that the channel is longer in the e3d version. I'm pretty sure the channel length is the key difference in this case in his video. Just watch for a few seconds starting at 12:28 (link should jump you to 12:28).
But check out the internals of a 3dsolex "race" nozzle!:
On 6/3/2019 at 11:28 AM, gr5 said:We call this kind of "fir" stringing. stringing is a little bit of nozzle leakage in a straight line between two points that the nozzle moves between.
I have just started to suffer from "Fir" after switching to a Micro Swiss hotend with the "high quality" nozzle that it came with.
oddly enough the cheap nozzles I had used before almost never had this problem, to the extent I did not even know it was a thing other than normal stringing.
but good to see your guys inputs here has given me great insight, I started to suspect it was the nozzle but was hesitant to try since its brand new and had no reason to preform badly.
Super old thread but thought I would put in what I found as I recently ran into this issue. Fir not stringing.
It all started after using VoxelPLA in black. It was just one spot of a model I print hundreds of. It got worse and worse. I finally got tired of it and switched back to hatchbox pla but the stringing continued. So I figured I change out my nozzle to a fresh one but all on my luck the fir continued just as bad. WTH why?
I finally found the one setting for me that improved it in Cura. It was the "Outer Wall Wipe Distance". I had it set to 1.2mm as I use a .6 nozzle. I set it to .6mm wipe distance and the fir was at least cut in half to almost gone in the trouble area.
I have another theory as to why it continued after a nozzle change and into Hatchbox filament which never had that issue before. It might have to do with particles left in the extruder gears from the voxel filament? Just a thought, but I am not going to pull apart my orbiter extruder as it seems to be improved with the new settings.
Hopefully this helps anyone who was spending hours searching google and came up to this thread from 2014. Let us know if it improved your "firry" issue.
Top Posters In This Topic
17
15
13
10
Popular Days
Sep 11
16
Oct 14
16
Sep 10
12
Sep 17
8
pm_dude 17 posts
ultiarjan 15 posts
gr5 13 posts
DidierKlein 10 posts
Popular Days
Sep 11 2014
Oct 14 2014
Sep 10 2014
Sep 17 2014
Popular Posts
Bryancm1
gr5
We call this kind of "fir" stringing. stringing is a little bit of nozzle leakage in a straight line between two points that the nozzle moves between. "hair" is usually a strange phenomen
gr5
Posted Images
IRobertI 516
Good, because I was naughty and used it before I got the ok from you
I had a feeling you'd be ok with it though
