Using a Microsoft Kinect to scan image for printing?
LePaul
Posted · Using a Microsoft Kinect to scan image for printing?
Don't expect anything in the micron resolution out of something that costs less than 1000 euro ;)
I haven't worked with it, but from the specs, i'd estimate that the new kinect is better, but not orders of magnitude better.
    • Replies 62
    • Created
    • Last Reply
    I know this thread has not been active for a long time, but anyway. Have anyone here a kinect 2 windows, and dona aa scan with it?
    How good resolution was it? in microns?
    I have one laying somewhere. Was unable even to extract an STL file from the format it records to. Left the idea there. Any clues would be appreciated, BTW.
    Well the thing is....we have these printers to print hi-res...and the Kinect stuff I messed with did a lousy job (which would have lead to a lousy print)...if you guys find something or have better results, do tell!
    Posted (edited) · Using a Microsoft Kinect to scan image for printing?
    clue; use Skanect software ... ( I only tried with a kinect 1)
    http://skanect.occipital.com/download/
    Do note that you need a pretty decent video card to get good results from skanect.
    but Skanect never went on with the new Kinect, they couldn't get it to work.
    That's really weird. It outputs a depth map just like the 'old' device. I can also find multiple open source implementations who did got it to work.
    I guess they prefer to sell structure sensors .....
    I've been using the ppt gui (osm bundle) that can do this with an ordinary camera!
    It's been used in archology, but you can use it in wathever.
    Very hard at first to get good results, but the effort pays of. Caveats; shiny surfaces and bad lighting. No rig required!
    Example ;
    https://www.youtube.com/watch?v=CxrP1TcdqDc
    Download here;
    http://184.106.205.13/arcteam/ppt.php
    If intrested I'll dig up what I know of it.
    this is the post from the Skanect forum about the Kinect V2
    https://groups.google.com/forum/#!topic/skanect/j8-hqrZIu-U
    V2 is little better detail but problems with eyes, hair, black, shiny etc.
    For those who want to use Kinect V2 (Xbox One Kinect) as a scanner, here are some options and general fyi.
    Microsoft 3D Builder - Free, requires powerful machine to get an easy scan; messing up tracking typically means restarting, directional lighting conditions not so much a problem. Takes longer to do the scan the slower your computer is, requires high fps from Kinect.
    KScan3D - (kscan3d.com), used to be $300, now free. Easier to use then Microsoft 3D Builder (IMHO), doesn't need as powerful of a machine. Takes single 3D Snapshots and auto-aligns them. Directional lighting not as big of a problem because the program seems to alter brightness, but you'll still need plenty of captures. Also, messing up on alignment is a pain to fix. Quality seems low on some scans, I assume it's the bad scan data.
    SFL:Standard - (scanfromlife.com), $75, no demo yet. Filters out the garbage and cleans up the sensor data. Outputs full color PLY directly from sensor data (so resolution is max possible). Doesn't auto-align 3D Snapshots, you have to use MeshLabs or other external program to do that. Doesn't touch color, so directional lighting is a problem (either have 1 light source over head or unfocused ambient lighting). Pro is it only needs 1 fps from Kinect to work, so low powered laptops can be used to take 3D Snapshots with. I took six 3D snapshots around a person with a dinky laptop, copied them to my more robust workstation, and then I was able to create a full color model.
    From what I've researched, the Kinect V2 is made more as a 3D Motion Sensor than 3D Scanner, the sensor outputs a lot of bad data which can make scans unreliable (flat walls appear bumpy, edges have random spikes, etc), because of this it seems most 3D Scanning Software companies are not supporting it.
    To use it like other 3D Scanners that build the 3d model in real time, you'd need a powerful machine to handle averaging out the bad data with the good. But if you're going to spend a lot on a powerful machine, imo might as well pay a bit more for something that was built as a 3D Scanner.
