I'm not using Creo Elements/Modeling PE, but rather Creo Parametric. It saves STL files in whatever units the model is created in and there's no option at the output to change it.
The process to change units is probably about 12 or more clicks and then when I'm done exporting, I have to do it all over again to revert back to inches.
Doing the conversion in Cura is certainly shorter, but sometimes the models come in and are too small to see.
Top Posters In This Topic
11
9
7
7
Popular Days
Mar 5
10
Sep 4
9
Mar 7
7
Feb 11
6
y8s 11 posts
nallath 9 posts
Dim3nsioneer 7 posts
amyinnh 7 posts
Popular Days
Mar 5 2015
Sep 4 2015
Mar 7 2015
Feb 11 2015
Popular Posts
geert_2
The whole world has switched to the metric system officially, so I think we should stay with the metric system. And not go back to medieval units that don't work well in high-tech environments, no mat
nallath
The community is not, but I do believe that you should be the change that you want in the world. So thats why I made the barbarian plugin. Partially as a joke (hence the name), partially to also somew
SkyKorp
As I peruse these forums I had high hopes when I found others that asked for this same feature that would make my life easier, yet only to find pages and pages of banter on why cura users need to lear
Posted Images
gr5 2,192
Creo doesn't do inches. Internally it only stores things in mm so it properly always outputs STL files in mm just like Cura likes it. I think you didn't tell Creo you are doing inches. it sounds like a system setting in Creo to set it in inches mode. If you don't do that what you think is 1 inch is actually 1mm. More explanation here:
https://www.ptcusercommunity.com/thread/33296
