HELP needed! Please can someone print the Black Plastic
Head assembly parts for UM2 and ship it to client in the UK?
They need to be tested to fit please. Ill send 3 nozzles as "reward".
Anyone? address to ship to from me by PM.
Edit: it is done! thanks
12
10
10
8
Popular Days
Jan 5
10
May 8
9
May 7
8
May 13
7
swordriff 12 posts
ultiarjan 10 posts
Volpino74 10 posts
gr5 8 posts
Popular Days
Jan 5 2016
May 8 2015
May 7 2015
May 13 2015
Posted Images
ultiarjan 1,223
When printing at high temperature the ptfe gets damaged. If you take it out of your machine and push some filament through it you should not feel any friction. Usually you see it's damaged as the small bottom is black and damaged. How often you need to change seems to be depending on many things like printing temp, and the pressure on it. You may not have to change it for years if you only print PLA at 205 celsius...
When you use a olsson block you can just remove the nozzle and feel if there's friqtion without the need to take the head appart, so thats another advantage of the olsson block...
Where best to get a ptfe it is depending on you location, I mostly get mine at a local shop (www.makerpoint.nl) but you can buy at ultimaker (not always the fastest), in the us at http://fbrc8.com/collections/ultimaker-2-spare-parts or get the 3dsolex version at 3dsolex.com (europe) or gr5.org/store/ (us and canada) (edit by gr5: fixed final link)
Edited by gr5Link to post
domustyle 23
damn thats crazy. haha
Edited by GuestLink to post
