4,297 -
33
Posts posted by Dim3nsioneer
Do you have material loaded in both extruders? The UM3 with firmware 3.5.3 does not heat up the bed when no material is loaded.
In the network menu go to the status entry and scroll down until the mac address appears...
Get in contact with your Ultimaker reseller. He should be able to organise the necessary parts for you.
Is that cheap glass really Borosilicate?
I have recently been in contact with a manufacturer of Borosilicate glass quite well known in Europe and they told me that their borosilicate glass is not manufactured with the aim to get even surfaces.
Standard glass is often much flatter than borosilicate glass. And I have no doubt you can buy a 'cheap borosilicate glass' in China which would turn out to be standard glass if checked with appropriate methods.
One more remark to the test method: please be aware you are testing not only the flatness of the glass but also the straightness of the axes (although Ultimaker axes are very straight nowadays).
Polymaker has a new promising support material
And what am I doing finally with the alcohol/702 solution?
Den UM2+ Feeder bekommt man als Ersatzteil, aber nur auf Anfrage via Ultimaker-Händler. Löcher dafür müssen aber natürlich selbst gebohrt werden.
Ich würde aber empfehlen, zwei gleichartige Feeder zu verwenden.
Last call: If anyone still wants to register for the Meet-Up at FabLab Lucerne on Wednesday next week, please do it now. We will close the registration soon as we are close to the maximum number of people the location can host.
The drop down box refers to the nozzle sizes Cura has a material profile for. If you add your custom nozzle size to those profiles and also to your machine via materials.txt you can have your custom nozzle size in the drop down box. But it's much easier to adjust the line width as suggested by @peggyb.
Dissolve that printed PVA in water and smear the solution with a clean cloth onto the glass, then let it dry by heating up the bed. PVA, PLA and Nylon should then stick like nothing to the glass.
Can you access the stream?
I moved it a bit and it started working again. maybe a cord? I'm scared to move it again lol.
You moved the printer? Then I guess it's a question of WiFi signal strength...?
@Dim3nsioneer, do you have the printer connected with WiFi or cable?
WiFi
Apart from the forced bed levelling and the 'forgotten' retract those issues sound to me rather like Cura issues. I think the new beta fixes the single extrusion with the second core; at least according the change log.
Connection to the UM3 from Cura 2.3.1 seems a bit delicate to me. I sometimes have the situation that Cura doesn't find the UM3 automatically and also not on a network scan. However, if I add the ip number, it immediately finds and names the printer.
As the UM3 is not compatible with 1.75mm filament I recommend to buy some spools of premium quality 2.85mm filament and make a nice birthday present or similar out of the 1.75mm filament for a fellow maker of yours...
- 2
Check if you can move any of the x and the y rods. If so, untighten one pulley of that rod and tighten it again so the rod does not move anymore. You may want to look how close to the edge the belts are running over the two pulleys in question and then decide which to move.
Da muss doch @Dim3nsioneer hellseherische Kräfte haben:P
Mist, da hat es doch einer rausgefunden...!
@DirkT: Das klingt mir danach als könnte man das Problem mit einem z-Hop lösen?
That's a really nice XT-CF20 print, @Wisar. Would you mind uploading it into the print section with some details about the Cura(?) configuration? How far did you have to deviate from a standard configuration?
Is it possible to have a productive 2.3.1 installation and a separated 2.4 beta version in parallel or do they use the same user directories and files as 2.1.3 and 2.3?
Wäre es dann nicht auch sinnvoller, die Frage nach einem neuen Drucker auf einem unabhängigen Forum zu stellen?
Je ne suis pas sûre mais je pense que le TweakAtZ a quelques problèmes avec des modifications en faible hauteur avec Cura 2.3.1. Regardez ici: https://ultimaker.com/en/community/34198-post-processing-plugin-tweakatz-51-not-wotking?. Là, je vais commenter s'il y a quelque chose de nouveau.
Well you can print abrasive materials, you just have to pay the price (of a new core). But the machine is capable of.
I guess @foehnsturm means the matchless race nozzle which has two channels for 0.4mm or larger.
Might be a nice thing to use standard (rsb jet) nozzles for the main print material and a matchless for the pva.
Remember this one?
in UltiMaker 3D printers
Well I guess atm everybody is quite busy to bring the UM3 firmware feature-wise up to the level of the UM2+ firmware and has no time for games...
