You could insert the snippet after the first line of skirt/brim gcode that way the head has already moved away from the prime area and has only done a small amount of movement on the bed.
But that would not work if skirt or brim is off.
anther way would be to loop over the whole gcode output and change the Z values but that would be really slow to process? for large-ish prints
Edited by ChrisRiddell
ahoeben 1,965
Good point @ChrisRiddell. The plugin currently does not take that into account, but I will see what I can do about that in a generic or customisable way.
