Ultimaker Community of 3D Printing Experts
Disable Automatic active bed levelling for Ultimaker S5
Posted · Disable Automatic active bed levelling for Ultimaker S5
Yes sir. I had to clean the tube as well. as there were particles of filament on the inner walls of the tube..
Thanks
    • Replies 56
    • Created
    • Last Reply
    Top Posters In This Topic
    Popular Posts
    This indeed not what would be expected. Would you be able to post your model and Cura settings? It is difficult to see only from the photo where it went wrong. We would love to research this. Did the
    This printer is amazing. But it would be intelligent to skip bedprobing between small jobs (or if a job was cancelled) to save some time. Once the bed is probed one should think it would stay calibrat
    Hi Abdu, good to hear that it is mostly gone! Tough PLA is a really nice material to print with. Do you have a photo of these one or two layers? Do they happen at random, or at the same height always?
    Posted Images
    okay.. so i did everything i could, but i am still unable to crack this. My Ultimaker S5 hasnt still been capable of beating my Ultimaker 3 with quality.
    What i noticed when i watched closely, is that after some really nice looking layers, the extruder starts extruding dots of filaments instead of proper lines. and that just ruins it by making the surface coarse and cracky. i had kept a 21hr print and noticed this happen many times in between. Here is an image of it:
    As you can see from the image, there is a band where there is less filament extruded.
    It would be great if someone can provide me exact settings for Tough PLA for a 0.25mm extruder.
    Am i missing out anything?
    There is the discrepancy between your experience and mine. I am using the 0.4 and 0.8 nozzle. I ahve not even tried the 0.25 I have on either my UM3E's or the S5.
    Have you tried the TPLA on the UM3E as well?
    No. i havent tried it on my UM3.
    But there is one thing i am 100% sure of, and that is, that there is some problem with my UMS5. The Innofil i used previously also had the same problem, but less, whereas the UM3 worked fine with the same Innofil material, with a 0.25mm print core.
    Posted (edited) · Disable Automatic active bed levelling for Ultimaker S5
    While that sounds logical, I would not trust the intuition, even on my own part, without putting the 0.25 on the UM3 and the TPLA to do a comparison. I just find that there almost always seems to be something different between actuality and thought experiments, especially when comparing different filaments.
    For instance, my 0.4 nozzle and White TPLA on the S5 is printing every bit as good as my PLA and 0.4 on the UM3Es I have here.
    Edited by kmanstudios
    Hi all
    I think this thread is never going to end.
    After i had tried everything to fix this problem, one solution seemed to make the situation better, and that is, to print TPLA at 225C.
    But then, i noticed something with the next print. that is, that areas where the support material is, the straight walls along z axis, arent straight. there are some layers left and right, and not exaclty on top of each other. PS, this is only if the wall is has support beside it.
    So then, i tried doing the XY Calibration again. The calibration print, bought a facepalm. I am shocked. I am using a genuine Ultimaker, Ultimaker branded nozzle, ultimaker materials, ultimaker slicer(Cura),but still, things doesnt seem right.
    In the first image, as you can see, when i align the grid for X correctly, the Y goes tilted(Red arrows).
    Also, the numbers and the long PVA lines are not aligned properly(Yellow arrow)
    In the second image, Notice the nice and good black lines(purple cirlce), and those underextruded dots(Blue circle).
    Am i missing something guys?? i am highly frustrated with this now. i have lost lots of filament and time for this. I have done literally everything i could.
    I did the following:
    manual Bed levelling.
    Cleaning 2 weeks old print core
    Changed to UM filament
    cleaning Bowden Tube
    Factory reset
    Firmware Update
    Changes USBs(sounds silly, but i tried everything i could)
    Print through Network
    Doing the entire maintainance procedure
    Loosening the feeder
    cleaning the feeder
    The only step i feel i am missing, i think, is to return this printer. I regret buying this. Should have gone for Sinterit SLS printer or maybe Formlabs..
    just a thought, but have you contacted your reseller to either get it fixed or swapped out?
    It would be a big cost for me to ship such a heavy package, get it fixed, and shipped back.. As i am in Kuwait, and my reseller is in UK.I have already paid a big price for getting it here.
    Your reseller should take care of those costs since they may have shipped a faulty product or was damaged in shipment. That would be my line of reasoning.
    I have had absolutely none of those issues you described and I am brutal on my machines.
    Thanks kmanstudios for your reply..
    Does Gr5 or SandervG have any suggestion ? Would be really helpful for me..
    @gr5 is far more knowledgeable than I am. He may have an idea that I am not experienced enough to suggest. While I 'feel' my way through my machines, he has it down to language and much, much more experience to draw upon.
    I am tagging @SandervG just in case.
    To properly tag someone so they get a notice, use the "@" symbol, start to type their name and click on the relevant name that pops up. If it is not highlited in blue, then it will not register as a tag for notification.
    Thanks for taging them for me..
    Well the thing is, it took nearly 8 days for my printer to arrive her via DHL due to customs issues. I have prints to deliver and cannot afford to waste so much time in sending the printer, getting fixed and getting it back.
    I will however try using my 0.4mm nozzle for giving a test print and look out for underextrusion. If problem is solved, i will order another 0.25mm nozzle considering i got a faulty one.
    If problem persists, i will take is as a bad luck ?
    i think the nozzle might fix the underextrusion, but im really confused about the alignment.. Expecting some helpful fixing suggestions from @gr5 and @SandervG
    Just out of curiosity, what do you require a 0.25 nozzle for? I have gotten some really nice details out of the 0.4 nozzle.
    OH!!! flapdoodle....I just realized something!!! ARRRRgggghhhhh....
    There is a change in the nozzle design on the S5. I wonder if that has something to do with it. And, you can take the 0.4 nozzle that came with it and actually turn down line width to make it a little bit more fine in picking up details. It forces the software to sub-sample the geometry a bit finer. But, there are no 0.25 nozzles incorporating the new designs to work with the new silicone pad design.
    Please give that a shot. I am so sorry for the lateness of the thought. But I have used that to beef up my design details in print.
    Also, if you can post a model that you are trying to print, I would love to play with it a bit just to see what I can slice. I cannot print it out because I am keeping my S5 in constant prints for either things I am working on (days at a time) and for clients (again, days at a time for prints) because I use it to print large things with fine details.
    But, fine for my purposes may not be as fine as you need.
    Hi
    I dont think the silicon pads have anything to do with the print quality. I have read your reply nearly 10 times by now, but fail to understand that even if Ultimaker have launched a new nozzle design, how come the UM3 0.25mm nozzles fit so well on the UMS5.
    If you see in this image, UM says they support the 0.25mm nozzle. So its nothing to do with not supporting it.
    However, i take your word pal. Giving 0.4mm Nozzle a shot..
    Will let you know how it goes
    I do know that the nozzles on the S5 are designed to work with the new pads for a variety of reasons. That would have to come from someone much more in the know. The graphic you posted should be addressed by someone at UM just because anything else is conjecture on my part.
    As for taking my word for it, I am just thinking of things to try because I just do not have the issues you are talking about.
    I put the 0.4mm nozzle. Results: The underextrusion issue is solved.. the filament comes out really well.
    BUT.. The calibration print does remain tilted for Y axis if i align for X axis.. Any ideas?
    That, I would have to think about.
    But it did occur to me that they may not have made the profiles optimized yet for the 0.25. That may have been the problem......
    Try to slice your object(s) for finer detail by changing the line width to something like a .26 width......see if that help with the print.
    With the 0.4mm nozzle, in cura, i get a orange colour on the textbox when i enter 0.4mm or below.
    one thing. after getting extrusion right from the 0.4mm nozzle, i pulled out the 0.25mm nozzle from my Ultimaker 3. and put it into UMS5, and then did a calibration print. This time, i get the extrusion right. So i think, the problem, is the nozzle. I think i should order another nozzle from my reseller after giving it a test print to confirm.
    BUT, the tilt in alignment still persists. one thing i noticed, is that the tilt in alignment with 0.4mm is way lesser than the tilt with 0.25mm(Both old and new nozzle) .
    I really need @gr5's help here.
    Thanks
    I think he would be better for that problem.....
    As long as it is not red you are ok.....it is a warning that you are going into possibly going too far. But I have made it work.
    This is a better solution for sure. And, yeah, I would contact the reseller about that since the nozzle is obviously the issue as we now see. Also, good to know that the UM3 nozzles work fine with the new silicone pads. :)
    Keep us posted :) I wold like to know your results as this is a new machine and so many new variables to take into consideration.
    Okaayyy!!.. So i made a test print with my Ultimaker S3's 0.25 nozzle on Ultimaker S5, and the print is just amazing. i have to say, i have never expected it to be so neat. the layer lines are invisible.. its a lovely print.  it was 4 walls of 0.5mm in my CAD file, and print came out to be 0.51mm, thats really impressive.
    Here is an image:
    Ignore the base, thats because i pushed my scraper way to hard in excitement ?
    But, the alignment issue of the calibration print still haunts me. Have to do something for that.
    Thanks..
    Here is an image:
    Thanks..
    This is a bit of a necro, but the calibration print is supposed to be misaligned except for in 1 place. Thats how the machine knows how to calibrate itself.
    found this post via google, figure other people might too.
    I am printing hundreds of small parts sequentially. I need the prints to be independent but i do not want to wait for bed leveling for every print. Is there a way around that ?
    Bed leveling takes 1 minutes and i have 100 small parts to print, that means 100 minutes of waiting. I am printing tensile specimens and they need to be printed individually.
    Please advise.
    Another small question, is it possible to adjust nozzle temperature during print with the S5 ? (The  universal option called "Tune" )
    Edited by RamiR9
    Please advise.
    It is not possible to disable bed leveling because it is crucial to a successful print to have a levelled bed and proper adhesion. Could you print multiple at the same time perhaps, on 1 build plate?
      • Talking additive | The 3D printing podcast
        Why should we be the only ones asking questions? Join us and ask Jabil all your questions on September 22nd 5pm CET
      • Ultimaker masterclass: Optimizing your Ultimaker Cura workflow
        Save your seat for either broadcast on September 23.
        What will you learn?
        · Best practices for iterative print preparation and every lesson you should learn from each print
        · The right way to use per-object settings and when they are most useful
        · Easy-to-use resources for anyone who wants to develop their own printer definitions, plugins, or print profiles
        · How to optimize print profile settings and whether to “keep” or “discard” changes
        · When is the right time to export your drawing from CAD? (Based on Ultimaker Cura’s surprising power as 3D control software)
        · And a whole lot more tips and tricks!
        How can I join?
        This free masterclass will take place twice:
        1. 11am CEST (5pm SGT, 5am EDT)
        2. 5pm CEST (11am EDT, 8am PDT, 11pm SGT)
      • Do you use 3D printing at work? Let us know
        It doesn't matter if you are using 1 Ultimaker or 10, there is inspiration in everything. We're looking for ...
        • 1 reply
