Now available: Ultimaker Cura 3.6 | Stable
Guest maht
Posted · Now available: Ultimaker Cura 3.6 | Stable
Since installing Cura 3.6 I have found that it has a very large memory leak, I have disabled all plugins excepy octoprint and auto orientation, and I am find that after a print memory usage keeps going up until my PC (Windows 10) becomes unresponsive.
Cura using about 8gig of RAM.
Was previously using 3.5.1 and have never had this issue with Cura before.
Any Ideas
Thanks
Steve
    13 hours ago, BrianTheCookie said:
    I understand that you guys are trying to optimize the print one at a time function for the Ultimaker, but other 3D printers, especially those that have a moving Y plate can do much more if this function is given more options and less boundaries and safety offsets.
    1
    It's up to the manufacturers of those machines to contribute these kinds of improvements back to us (or hope that an open source contributor does it for them)
    Could you test if this version of the plugin still exhibits the leak when you configure it not to display the camera image?
    http://files.fieldofview.com/cura/OctoPrintPlugin-v5.0.0-2018-11-14T21_29_30Z.curapackage
    Just drop the downloaded file into a running Cura window, and restart Cura.
    I don't think this version will fix the memory leak (though it might), but it will help diagnose where/what is leaking. Version 3.5.2 of the plugin (which I think you have installed) has a bug that even when not displaying the image, it is still being streamed and interpreted (oops).
    16 hours ago, leliep said:
    Similar for me. On my 2018 MacBook Pro it takes about 2...3 minutes to start up, using 100% CPU. During this time it displays "updating configuration", before it eventually shows the GUI and becomes responsible. This behavior is reproducible. I guess Cura 3.6 needs some kind of serious tuning 😉
    Btw., I like the Gyroid infill!
    1300232686_Bildschirmfoto2018-11-15um23_41_25.thumb.png.701f8bd8217023ece1242c2f3d3d6345.png
    1259988939_Bildschirmfoto2018-11-15um23_41_44.thumb.png.c5f2e52be295b0c5600935c847e1a17a.png
    I can confirm, cura starting from 3.5 version is unusable on macbook air 2011.
    I just installed the 3.4.1 version and it's a lot better. Normal cpu usage during slicing and rotating view specially in layer view.
    On a Macbook Pro 2018 it is running fine with latest MacOS 10.14.1.
    I guess it is related to some libraries which are too old in older MacOS versions.
    Posted (edited) · Now available: Ultimaker Cura 3.6 | Stable
    This is mine... brand new and up-to-date. And Cura 3.5x did run perfectly.
    45949763_Bildschirmfoto2018-11-16um21_31_59.thumb.png.728e5b67f795353308e1c83f849b29da.png
    Edited by leliep
    In my case I just installed osx high sierra. All other slicers are working fine (S3d, idea maker, Slic3r PE etc.)
    What about this for a slow startup on MacOS...?
    UM.VersionUpgradeManager._getUpgradeTasks [281]: Failed to get file version:
    ~/Library/Application\ Support/cura/3.6/cura.log contains an endless number of lines with this kind of messages.
    2018-11-15 22:53:20,838 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [422]: Loaded plugin FileLogger
    2018-11-15 22:53:20,849 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [422]: Loaded plugin LegacyProfileReader
    2018-11-15 22:53:20,860 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [422]: Loaded plugin SimpleView
    2018-11-15 22:53:20,873 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [422]: Loaded plugin SolidView
    2018-11-15 22:53:20,891 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [422]: Loaded plugin FirmwareUpdateChecker
    2018-11-15 22:53:20,907 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [422]: Loaded plugin SupportEraser
    2018-11-15 22:53:20,919 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [422]: Loaded plugin PrepareStage
    2018-11-15 22:53:20,950 - DEBUG - [MainThread] UM.Backend.Backend._logSocketState [178]: Socket state changed to Listening
    2018-11-15 22:53:20,979 - INFO - [MainThread] UM.Backend.Backend.startEngine [74]: Started engine process: /Applications/Ultimaker Cura.app/Contents/MacOS/CuraEngine
    2018-11-15 22:53:20,983 - DEBUG - [MainThread] UM.Backend.Backend._backendLog [94]: [Backend] Calling engine with: ['/Applications/Ultimaker Cura.app/Contents/MacOS/CuraEngine', 'connect', '127.0.0.1:49674', '']
    2018-11-15 22:53:20,987 - DEBUG - [Thread-18] UM.Backend.Backend._backendLog [94]: [Backend]
    2018-11-15 22:53:20,997 - DEBUG - [Thread-18] UM.Backend.Backend._backendLog [94]: [Backend] Cura_SteamEngine version 3.6.0
    2018-11-15 22:53:20,997 - DEBUG - [MainThread] UM.Backend.Backend._logSocketState [182]: Socket state changed to Connected
    2018-11-15 22:53:21,000 - DEBUG - [Thread-18] UM.Backend.Backend._backendLog [94]: [Backend] Copyright (C) 2018 Ultimaker
    2018-11-15 22:53:21,008 - DEBUG - [Thread-18] UM.Backend.Backend._backendLog [94]: [Backend]
    2018-11-15 22:53:21,008 - DEBUG - [MainThread] UM.Backend.Backend._onSocketStateChanged [172]: Backend connected on port 49674
    2018-11-15 22:53:21,011 - DEBUG - [Thread-18] UM.Backend.Backend._backendLog [94]: [Backend] This program is free software: you can redistribute it and/or modify
    2018-11-15 22:53:21,016 - DEBUG - [Thread-18] UM.Backend.Backend._backendLog [94]: [Backend] it under the terms of the GNU Affero General Public License as published by
    2018-11-15 22:53:21,021 - DEBUG - [Thread-18] UM.Backend.Backend._backendLog [94]: [Backend] the Free Software Foundation, either version 3 of the License, or
    2018-11-15 22:53:21,028 - DEBUG - [Thread-18] UM.Backend.Backend._backendLog [94]: [Backend] (at your option) any later version.
    2018-11-15 22:53:21,029 - INFO - [MainThread] UM.VersionUpgradeManager.upgrade [130]: Looking for old configuration files to upgrade.
    2018-11-15 22:53:21,032 - DEBUG - [Thread-18] UM.Backend.Backend._backendLog [94]: [Backend]
    2018-11-15 22:53:21,036 - DEBUG - [Thread-18] UM.Backend.Backend._backendLog [94]: [Backend] This program is distributed in the hope that it will be useful,
    2018-11-15 22:53:21,039 - DEBUG - [Thread-18] UM.Backend.Backend._backendLog [94]: [Backend] but WITHOUT ANY WARRANTY; without even the implied warranty of
    2018-11-15 22:53:21,043 - DEBUG - [Thread-18] UM.Backend.Backend._backendLog [94]: [Backend] MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
    2018-11-15 22:53:21,046 - DEBUG - [Thread-18] UM.Backend.Backend._backendLog [94]: [Backend] GNU Affero General Public License for more details.
    2018-11-15 22:53:21,050 - DEBUG - [Thread-18] UM.Backend.Backend._backendLog [94]: [Backend]
    2018-11-15 22:53:21,054 - DEBUG - [Thread-18] UM.Backend.Backend._backendLog [94]: [Backend] You should have received a copy of the GNU Affero General Public License
    2018-11-15 22:53:21,058 - DEBUG - [Thread-18] UM.Backend.Backend._backendLog [94]: [Backend] along with this program.  If not, see <http://www.gnu.org/licenses/>.
    2018-11-15 22:53:21,088 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [281]: Failed to get file version: ./.DS_Store, skip it
    2018-11-15 22:53:21,091 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [281]: Failed to get file version: ./packages.json, skip it
    2018-11-15 22:53:21,093 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [281]: Failed to get file version: ./plugins.json, skip it
    2018-11-15 22:53:21,097 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [281]: Failed to get file version: 3.3/.DS_Store, skip it
    2018-11-15 22:53:21,101 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [281]: Failed to get file version: 3.3/plugins.json, skip it
    2018-11-15 22:53:21,103 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [281]: Failed to get file version: 3.3/cache/.DS_Store, skip it
    2018-11-15 22:53:21,105 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [281]: Failed to get file version: 3.3/cache/definitions/3.3.1/ultimaker2_extended, skip it
    2018-11-15 22:53:21,108 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [281]: Failed to get file version: 3.3/cache/definitions/3.3.1/ultimaker3_extended, skip it
    2018-11-15 22:53:21,111 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [281]: Failed to get file version: 3.3/cache/definitions/3.3.1/ultimaker3_extruder_left, skip it
    2018-11-15 22:53:21,114 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [281]: Failed to get file version: 3.3/cache/definitions/3.3.1/ultimaker_original, skip it
    2018-11-15 22:53:21,118 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [281]: Failed to get file version: 3.3/cache/definitions/3.3.1/fdmprinter, skip it
    2018-11-15 22:53:21,122 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [281]: Failed to get file version: 3.3/cache/definitions/3.3.1/ultimaker_s5, skip it
    2018-11-15 22:53:21,125 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [281]: Failed to get file version: 3.3/cache/definitions/3.3.1/ultimaker2, skip it
    2018-11-15 22:53:21,129 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [281]: Failed to get file version: 3.3/cache/definitions/3.3.1/ultimaker3, skip it
    2018-11-15 22:53:21,132 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [281]: Failed to get file version: 3.3/cache/definitions/3.3.1/ultimaker2_extended_plus, skip it
    2018-11-15 22:53:21,136 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [281]: Failed to get file version: 3.3/cache/definitions/3.3.1/ultimaker2_go, skip it
    2018-11-15 22:53:21,139 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [281]: Failed to get file version: 3.3/cache/definitions/3.3.1/ultimaker2_plus, skip it
    2018-11-15 22:53:21,142 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [281]: Failed to get file version: 3.3/cache/definitions/3.3.1/ultimaker3_extruder_right, skip it
    2018-11-15 22:53:21,146 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [281]: Failed to get file version: 3.3/cache/definitions/3.3.1/imade3d_jellybox, skip it
    2018-11-15 22:53:21,149 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [281]: Failed to get file version: 3.3/cache/definitions/3.3.0/ultimaker3_extruder_left, skip it
    2018-11-15 22:53:21,152 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [281]: Failed to get file version: 3.3/cache/definitions/3.3.0/ultimaker3_extruder_right, skip it
    2018-11-15 22:53:21,155 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [281]: Failed to get file version: 3.3/cache/definitions/3.3.0-BETA/ultimaker3_extruder_left, skip it
    2018-11-15 22:53:21,158 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [281]: Failed to get file version: 3.3/cache/definitions/3.3.0-BETA/ultimaker3_extruder_right, skip it
    2018-11-15 22:53:21,161 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [281]: Failed to get file version: 3.3/quality/.DS_Store, skip it
    2018-11-15 22:53:21,166 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [281]: Failed to get file version: 3.3/3.2/cache/definitions/3.2.1/ultimaker2_extended, skip it
    2018-11-15 22:53:21,169 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [281]: Failed to get file version: 3.3/3.2/cache/definitions/3.2.1/ultimaker3_extended, skip it
    2018-11-15 22:53:21,172 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [281]: Failed to get file version: 3.3/3.2/cache/definitions/3.2.1/cartesio, skip it
    2018-11-15 22:53:21,175 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [281]: Failed to get file version: 3.3/3.2/cache/definitions/3.2.1/ultimaker3_extruder_left, skip it
    2018-11-15 22:53:21,179 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [281]: Failed to get file version: 3.3/3.2/cache/definitions/3.2.1/ultimaker_original, skip it
    2018-11-15 22:53:21,182 - WARNING - [MainTh...
    I don't know, but 3.6 is staring as fast (or slow) as all other previous versions. Cura isn't the fastest app when starting, but it takes no longer than 10 seconds.
    For me it takes 184 seconds.
    Definitely too long.
    You could try to delete Cura and delete everything in your <home>/Library/Application Support/cura
    But make a backup before if you have a lot of customizations (profiles, materials, etc)
    Then try again with a fresh copy of Cura 3.6. I guess that there is a problem converting the older configurations which are all stored in the above location.
    Anyone else find that when gyroid infill is used that the time to print in cura is way out from real life? (Using Ultimaker S5 to print) In Cura it said 14 hours 12min, but real world was 19 hours 37 min what i find to be way way out next to using one of the normal infills i used before 3.6
    Hello @Carla_Birch. Yes, I noticed that the gyroid infill appears to take longer to print than the estimated time. Sorry, I don't know why that is. My guess is that there is a mismatch between the values that Cura is using to calculate the time (distances, acceleration, jerk values, etc.) and the values used by the printer firmware. The gyroid infill gcode does not add any explicit delays or require much travel.
    On 11/15/2018 at 3:34 PM, BrianTheCookie said:
    @maht {snip}
    One more change I would like to suggest would be to reinstate the filament diameter option in the sidebar. This will allow users to easily adjust flow if a particular spool of filament is over or under spec. Thank you.
    I second this. Please put it back in - that would help a lot on my end.
    Thank you,
    Gary
    Thank you, I will test and see
    Steve
    On 11/16/2018 at 5:35 PM, Smithy said:
    [...] Then try again with a fresh copy of Cura 3.6. I guess that there is a problem converting the older configurations which are all stored in the above location.
    FWIW: Loading Cura 3.6.0 on a MacBook Air 2014 with 1.7GHz i7 8GB RAM and SSHD running 10.14.1 Mojave takes about 14 seconds. This is an install over 3.5.1 with a couple of printer profiles customized.
    Edited by bobstro
    14 seconds sounds ok, mine needs 10 seconds to start, so depending on the profiles it could take 4 seconds longer.
    The problem for me is after program charging. Any click on GUI halt cura for at least 7/10 seconds Each time. Then layer view is almost unresponsive. 🤐
    What happened after 3.4.1? That is the last version that is working fine
    I saw that development moved to a newer version of QT. Could this be the problem?
    Edited by pieri70
    Cura 3.6 seems to print support brims before it starts printing the normal skirt. This way, if there is some residue on the nozzle, it's not on the skirt but instead get's wiped on the brim, which is bad.
    I guess it is, but there were also some problems before. For example, the custom settings after you enter something in the search field, the items are shown only after some seconds and then only one by one.
    I think it is a mix of new Cura version with some changes in the libraries and Apple changes some default libraries too.
    The problem was with both mac os el capitain and high sierra.
    So I think much of the problems are by cura itself..
    It's a pity.
    I'll get stuck with Idea Maker
    Thanks
    Pietro
    I have such problems always when the application is available for multiple platforms. It works but it is not as fast as native apps and there is always a very little delay in using the gui. Native MacOS apps don't rely on these libraries I guess and therefore they are much faster and more responsive. When I look back, there were a lot of Java apps, all for several platforms available and they were all slow and sometimes unresponsive. Cura frontend is written in Python but I think it relies also on those shared libraries for generating, viewing the gui elements and windows.
    For me it is usable, not fast as a native app, but not so slow that I can say, I cannot use it. And nothing has changed for me between 3.4.1 and 3.6., speed (starting, using) is/was always the same.
    System specs for you?
    I'll try with my sister macbook air as she will come and see me. It's last year model..
    I guess a dedicated graphics card is a lot better than the built-in Intel chip. Most Macbooks don't have dedicated graphics, only the 15" Pros or if you order it.
    Here is mine, also without a dedicated graphic card.
    2000536581_Bildschirmfoto2018-11-18um19_15_38.thumb.png.863f87b884d6bda82cb839ee3f279a9b.png
    And it has nothing to do with memory because at my office I have an iMac 2017 i5 with 24GB memory and speed is the same there.
    Hi, I am quite new to this, have an Ender 3 printer.
    Now, when first beginning a print, the extruder heater will not start to heat up until the bed has fully heated up. It was not like this on Cura 3.5.1  where both extruder heater and bed heater started up together and reached final temperature pretty much together. Makes a difference in my cold basement. Can 3.6 be made to work like 3.5.1 ?
