On 9/13/2020 at 6:17 AM, ChrisRowland said:I also have a problem with Cura 4.7.1, Windows 64 bit version.
I've been running 4.6.1 sucessfully and saw the invitation to upgrade so did. The install process worked.
But starting Cura doesn't. I get to the window asking for me to contribute by sending anonymous data and click on 'Next'
Cura silently closes. No error messages, nothing.
The same multiple times, even after a restart.
Has anyone tried this with W10? It seems pretty solid and as I've not even got to the point of selecting a printer seems pretty generic.
Will return to 6.7
Chris
I have been having similar problems using 4.7.1 after upgrading fro 4.4.1. the curved sections of the bow are very rough. The one on the left was sliced with 4.4.1 with totally default Ender 3 settings, the one on the right is with 4.7.1. They both have some odd excess pieces of filament, probably do to my new all-metal extruder, but I am quite sure that is unrelated...
Smithy 1,144
When you have Cura 3.6 installed and install 4.7 it should (should!) migrate all the settings you had in 3.6.
