I only have this fuzzy photo of printing:
http://daid.eu/~daid/IMG_20120522 ... .small.jpg
I first printed the underside of the case, then inserted all the gears, and then printed the rest of the case. But I had a bunch of test prints first to see if everything would fit and still rotate
You can see the 3 iterations of the rotating wheel, which was a ring with small dots first, then a big wheel, and finally the wheel with cats in it.
On the top there are 2 prints to see if it's possible to seal gears in a print, and to test the small gears.
On the bottom right you see the first rev case, which was too small and did not work.
On the top left you see the previous revision case, which had thicker gears and a slightly different inside tooth gear, which didn't work as good as my final one.
And we have:
This was step 2. First step is the big wheel, then you print the 3 small gears, then the center gear in which you need to insert the big wheel during printing.
I'm going to print another one, in less girly colors for myself. I'll see if I can take some more photos then.
362
282
221
179
Popular Days
Jan 5
30
May 12
26
Jan 13
23
May 1
22
ian 362 posts
cloakfiend 282 posts
skint 221 posts
SandervG 179 posts
Popular Days
Jan 5 2014
May 12 2014
Jan 13 2014
May 1 2014
Popular Posts
kmanstudios
Took me forever to do this. And it is still rougher than I would have liked. 3D concept rendering: Finished piece:
kmanstudios
I just finished this. It was a multi-part print for ease of painting. Some of it I am not sure what happened...but hey, it is purty....And, I am unanimous in that ? Test Render Parts
gr5
Bath interferometers. I have made about 20 of these for people who use them to test their telescope mirrors. They are amazingly accurate and can do better than a $40,000 Zygo PSI optical tester. Th
Posted Images
ian 32
seriusly cool Daid.
taking the ultimaker to he next level and also Cura of course.
It is really true, the only limitation to this technology is your imagination !
cool print, did you take any photos when the ultimaker started printing around the gears the casing ? that would be cool to see.
Also how did you position the gears, so the ultimaker knew exactly where to print the surround case, actually ? how did it print the under side of the case ith the gears lying on the work surface ?
super cool stuff Daid.
Ian![:D](//content.invisioncic.com/ultimake/emoticons/5a33abe7dfbbe_1f600copy.png)
