Post your latest print!
IRobertI
Posted · Post your latest print!
Yet another yoda.. This one was sliced in cura at 0.05mm layer height no infill, 1.2mm wall thickness. I printed at full size this time (print sitting on CD to show scale)
    Hitesh & armstorm - GREAT WORK!
    Both print look really good :)
    @armstorm: Is this ABS?
    @Hitesh: I guess with retraction, right? You had a modified extruder setup, if I'm not mistaken?
    Cheers
    Flo
    Cheers
    Flo
    Thanks! no, I printed with PLA.
    -Matt
    Thanks Florian! Yes i had retraction enabled and am using the mk6 gear.
    @concreteTurtle: The whistle looks great. Does it generate sound? I tried printing a similar one (or probably the same one)..it looked good, but did not have any sound..maybe i didnt have the infill set right..
    Hitesh
    Cheers
    Flo
    @approx - Nice Yoda! The chin and earlobes look pretty good, did you set a bridge % or use the default cura 100%? Also, which extruder design are you using with the mk6 gear, tlalexander's wade derivative?
    Kyle
    Kyle
    Yoda is Armstrom's print, not mine.. :)
    yea I use Taylor's wade extruder design
    Hitesh
    i love the United States Capitol !!
    super cool ! :D:D
    may i ask why you printed with supporting material, the ultimaker would have handled the columns no problem and then the roof ove :D hand would have wrested on them...
    or am i missing something... ?
    Best wishes.
    Ian :D
    super cool ! :D:D
    Best wishes.
    Ian :D
    Thanks Ian! Since the bottom of the model was uneven, I used support so that it would even it out..
    I don't really know how to use 3d software, but I am sure folks proficient in it could even out and straighten the base :)
    Hitesh
    super cool ! :D:D
    Best wishes.
    Ian :D
    Hitesh
    the question is ? why did the 3d modeller make it with a uneven base in the first place. maybe he was a little crazy and his hobby table was uneven, so he made the base to fit... ? :lol:
    super work.
    Ian :D
    Here is a Triceratops made for my kids using the simple mode high quality print in Cura (thanks Daid for the amazing piece of software). Lots of support structure which was hard to remove so the head is a bit clumsy. Temperature 215° (heavy stringing), silver PLA from GRRF. The print took 2h and 45 min.
    Nice print!
    Is this dinosaur model online? Looks like a nice "support benchmark" model :)
    Retraction will help against the strings. The strings also connect the support to the model, making it harder to remove. The next release of Cura will feature retraction when moving from/to support if you have retraction enabled.
    You could also try to lower the support material amount even more (25% or so) too see if that makes it easier to remove.
    Nice print!
    Thanks flouSH!
    No, it is a model exported from DAZ Studio, edited in Rhinoceros and cleaned with netfabb Studio. Online (free) dinosaurs are hard to find and are mostly over-simplified or with bad meshes. I had to make the foot wider because the first layer had a too small area and could not stick well to the print bed (and, of course detached from the print bed and moved away after half an hour printing time).
    Thanks Daid for the tips, I just wanted to test the "simple" mode with this example. The next dino will go through the expert mode with more playing around, with definitely less support material. In my case it was just too much of it.
    Talking about support material - is there any way to solve situations within Cura where support material should start somewhere above level 0 (like this example)?
    If not possible, is it somewhere on the wish-list?
    It's possible, but not in simple mode. In normal mode you can choose between 3 different support options. Easy mode uses "exterior only" if you enable support. But in your case you want "everywhere".
    Thanks.
    First test for stackable boxes which use a very low amount of plastic and thus are quick to print. A bit like lego bricks, but less stable. I have some more plans for these.
    A gift for a friend. Printed in Magenta from Ultimaker. If you are ordering from UM, I recommend getting a 0.75kg roll of Magenta, it's a really funky color that stands out. You get a sweet taste in your mouth by just looking at it.
    a quick snap at what i am up to at the moment.
    Basically ultimakering a city :D:D
    House by House.
    As my ultimaker prints out the next house, I build and prepair the next one, on the office computer upstairs.
    what is really cool is, i have the printer in the celler and have a webcam hooked up and live feed being sent to my office computer upstairs.
    So as I work and prepair more models, i can monitor the activity of the ultimaker :D:D very cool :D
    So here is a quick snap. enjoy.... i hope ?
    Ian ;)
    guys you are all printing every day ! new objects !
    get up off your lovely printing... bum bums and take some photos.... inspire the rest of us with what you have done !
    Ian :D
    that doesn't mean what we're printing is worth showing ;)
    In my case it is recently :D
    I forgot to share the stuff here.... so here we go: Img3548.thumb.jpg.dc9c4a3003dd2b92d32d7421f9434db7.jpg
    More about it:
    Pictures: http://goo.gl/wQmrH
    Thingiverse: http://www.thingiverse.com/thing:26408
    More is coming soon, which makes more sense then.
    Cheers
    Flo
        • 20 replies
