Temperature sensor stuck - UM2
colorfabb
Posted · Temperature sensor stuck - UM2
So I was hoping to replace the hot end on our first Ultimaker 2 during the weekend however, I stumbled upon a problem. The temperature sensor is stuck in the UM2 heaterblock.
I've tried heating it to 260C, but the sensor won't even wiggle a little, it's really really stuck in there.
@Ultimaker I really liked that the UM Original heater block had holes that poked through the entire heater block. This made it easy to remove since you could push the heater cartridge and sensor out using a screwdriver. Now the only method is to pull on the fragile wires which will break when the sensor is stuck.
Any tips on replacing a UM2 nozzle/heaterblock without replacing the temperature sensor?
Cheers,
Gijs
  • Like 2
Hi
Wow, so deeply seated the sleeve of the sensor, which was not with me some time ago that way. :shock:
Is this Hotend totally broken, unusable?
For better work on HotEnd I would disconnect the wiring from the MotherBoard. :idea:
Make on the narrow side of the HotEnd carefully an additional hole (3 to 4 mm with a Dremel or Proxxon, for example) near the edge region of the sleeve. Separating regions of the hole, so that a U-shaped gap on the side is formed by a larger portion of the sleeve to be more accessible. The sensor is located at the back end of the sleeve. You can with a suitable screwdriver, then the sleeve near its opening to squeeze something, so this (preferably hot) can be pushed out.
:idea: Maybe it's possible without additional drilling. Pinching the sleeve edge a bit so you can pry it out with a watchmaker's screwdriver.
Temperatures above 260 degrees will destroy the sensor presumably, please use no small burner such as a storm lighter, this mistake I made once with mounted sensor. Maybe it works better with an adjustable hot air gun, soldering iron.
Markus
    I had the same issue. By grasping the heater with locking pliers to avoid crushing it I was able to twist it to break it loose, and finally got it out. Perhaps a small amount of WD-40 could help loosen it up. (clean out thoroughly after).
    In any case, when you assemble the next one, use some anti-seize compound on the heater and the sensor to keep the issue from happening again. I'm surprised that this apparently isn't part of the assembly procedure.
    Perhaps this needs to be addressed by Ultimaker as an ISO 9000 quality issue...
    The short answer is No. Anti-seize is mostly powdered copper and aluminum in a base of grease. The grease may smell a bit for an hour after first use, but I've disassembled my hotend since using it, and the heater and sensor came out easily.
    @EldRick
    ? Did you mean something like this:
    http://nfieldgear.com/enfield-store/catalogsearch/result/?q=anti+seize
    Markus
    Fairy noof. I've ordered a 500g tin of automotive copper grease.
    Gijs, I just had this same issue and broke my sensor at the leads. The sensor sheath is so far into the block I can't get it out with tweezers or pliers. Now I have a bad nozzle and a bad sensor.
    Edit:
    I managed to get my sensor out. Used a screw about the same size as the temp sensor diameter and screwed it in tight then took some pliers and pulled the screw along with the sensor out. So thankfully I can use this nozzle still.
    same problem with my ultimaker 2. Unfortunately. After almost 2 hours of gently trying to remove it by heating up the nozzle at different temperatures i give it up finally.
    Next question is where to go from here? Cut the sensor and replace it? I have no problem releasing the heating part.
    I admit, the nozzle is a mess with burned filament but as i learn here, this is not something unusual to happen. So i agree, its a design flaw to make these parts that are easaly worn out to be so hard to replace.
    Herman
    Herman, contact support for a replacement nozzle and sensor.
    +1
    This needs some rethinking since i ruined my sensor after faulty reading.... 107€ for heatblock and sensor... damn.....
    +1 for this problem.
    I have been printing with abrasive filament, ordered a spare nozzle before and now tried to replace it as print quality has fallen off significantly
    -disassembly went smooth
    -heater comes out easily
    -temperature sensor stuck , looked online for instructions, tried heating the block by turning the machine on and using 'Heat nozzle' (after reinserting the heater)
    -tried wiggling the wire
    -temperature sensor eventually came out without its metal housing, which remained in the nozzle. Sensor destroyed and nozzle unusable
    Is there a better method to prevent destroying the temperature sensor each time I replace the nozzle?
    I love the machine, but this is definitely a downside.
    -Lieven
    Fablab Brussels
    Posted (edited) · Temperature sensor stuck - UM2
    Well there's 3 important things you can do:
    1) When inserting the temp sensor into the block if it is at all tight, remove it and use a drill bit to widen the whole ever so slightly.  A 3mm drill will work fine, or a #31 drill if you are in USA.  The 3mm drill should be loose in the hole, move it around against all the walls while spinning at high speed for about 6 seconds, blow out dust, try again until the fit is perfect.  If you go too far (unlikely) add some aluminum foil.
    2) Get an Olsson block: 3dsolex.com.  then you can change nozzles without changing block. 3dsolex sells cheaper temp sensors if Um won't give you a free one.
    3) Add a drop of light oil when it's stuck and let it sit for a few minutes.  Heat helps (but you tried that).  Also you can drill the block from the other side with a very small diameter drill - say 1mm.  When the hole hits the temp sensor you should hopefully feel it (be careful!).  then use a paper clip to push the temp sensor out.
    Hello gr5,
    thanks for the suggestions, I like all of them.
    -I just ordered a 3Dsolex block, though I had enough leaky nozzles before the UM2 that I understand the design logic behind making the nozzle and block as one part. Definitely worth trying though. I need something if I want to keep playing with that colorFabb carbon filament...
    -I don't need a freeby thermocouple. I'm much happier with an open-source manufacturer who sells spare parts at a reasonable profit and keeps supporting its older models, rather than one that first sends out replacement parts for free, but then removes spare parts for the Cupcakes from their store...
    best -Lieven
    Thx -Lieven
    Well you need to tighten the nozzle into the block very tight so it won't leak. But not too tight as brass isn't as strong as steel. Anders made a special torque wrench tool for this so I recommend you print the tool early on. It's about 5 inch pounds of torque (.5 newton meters).
    https://www.youmagine.com/designs/nozzle-torque-wrench
    Thanks all. I had the exact same problem with the temp sensor getting stuck in the block. I now have a useless nozzle with the metal casing of the sensor stuck inside.
    So i ordered a new sensor and now am having a little trouble reconnecting it. Where do i recconect? Do i need to completely unasseamble walls etc of the UM2? Or is there a simple way to remove the old sensor and add a new one (im ok putting the sensor in the heat block...its the other end im having trouble with.
    Thanks.
    i also found the sensor to be stuck. I got it loos in the end by adding a few drops of WD40 and then heating it to 260.
