Thanks GR5!
i absolutely agree on the fact that the makerbot is a pretty bad piece of equipment.. so i was not trying to compare the 2 machines quality wise, i am absolutely convinced the UM2 is way better quality wise. I was comparing them to how they are being presented. you can walk into a consumer store and buy a makerbot.. it's marketed as a consumer device. people get the same impression from the UM2.. but i believe we agree there
guidelines are simply needed..
as far as the cold pull, could you explain this a little better? this seems like a very good idea!
K.
gr5 2,210
Regarding makerbots - everyone who I've talked to and has one and also a UM (I've met maybe 20 people who have both) hate the makerbot compared to the UM. They say the quality is much worse and it keeps breaking and currently doesn't work at all but their UM is working great. 100% of the people who have both have told me this. Of course someone will now probably post below saying their makerbot is better and works fine, lol. Also I am told that their customer support is completely backed up for months now.
I totally agree with your perception about people buying UMO versus UM2 and makerbot. Part of the problem is the phrase "3D printing" which people and the press make it sound as simple as 2D printing. It should be called "additive manufacturing". 3D printing is just as difficult and complicated as using a milling machine yet my neighbors are much more scared of getting started on buying a milling machine.
Isolator
UM has improved the teflon isolator so that it will last longer and they are working on an all metal head I believe. Unfortunately that might be the UM3.
Atomic Method (aka cold pull)
I now do this on EVERY filament change. In fact I don't use the menu to change filament anymore. At the end of every print I set the temp to 90C and push the filament in a bit while cooling (unless I know for sure I'm printing again with the same color) and when it gets to 90C I pull the filament out the back. After it is almost to the feeder I let it cool another 20 seconds then pull fast and hard so a piece doesn't break off in the feeder. I then cut off the tip of the filament (two cuts at different angle to make a point) before storing the filament.
When I change colors I no longer have to wait to get all the old plastic out.
