In theory you could but...
- You would need to:
a) Use a pt100 amplifier to connect the hotend to the board or..
b) Design an adapter so you can have the thermocuple and swap the pt100 for your heat sensor
Also.
a) The x2 12V fans connected in series so they work as 24V they might or not work. I don't know if someone ever tested them on a umo 19vboard.
I think that's the two mayor problems points to solve.
flowalistik 181
Nice tutorial!
Now the UMO+ is more like a steampunk UM2+!
neotko 1,415
Upgrade Manual finished!
PDF Version at Youmagine:
https://www.youmagine.com/designs/um2-upgrade-on-umo-assembly-manual
Have fun!
Edited by SandervGLink to post
thevoltmaster 12
So will this work on an Ultimaker original? I have the Ultimaker heated bed platform kit that came with the 24v psu, but i cant quite grasp how my electronics are different from that of the UMO+. I really want to do this upgrade, Thanks!!!
