I can live with the slicing time... I find the lack off speed in layer view the most annoying....
I read that on Linux installing 2.1.2 nukes any 15.x.x installs you have. Is this the same on windows? I am not ready to lose all my 15.x.x stability and control.
Windows can install side by side.
- 1
Hi guys, loaded the new Cura, rebooted the computer, gone into Cura setup my machine and preferences in the system, loaded a part to check and test out, and it sits there saying "preparing to slice..." And going nowhere.
Are you on Windows? At first launch after Windows install, Cura is sometimes unable to connect to the engine. This can cause the slicing to remain at "preparing to slice". Restarting Cura should correct the connection problem.
Problem solved, there was a problem with my antivirus, it would allow previous versions to run ok but the new version it would block part running, I have now authorised the various aspects of the new Cura and its running fine
- 1
- 4 weeks later...
Cura 2.1.2 can not load 3mf file.
I uploaded stl to modelrepair.azurewebsites.net and download 3mf file.
Unfotunatelly Cura can not load it.
Error message says: "Failed to load" I don't know it is a modelrepair bug or cura bug.
Unfortunatelly it is possible to download fixed stl file in 3mf format only.
Previously I could upload stl and I could download stl too.
Any idea how can I solve it?
I'm guessing that the 3mf version that they use is incompatible with ours.
Are there different 3mf files? How can these be distinguished from each other?
Have you tried these steps?
There are different revisions of the .3mf standard.
I hope, Cura will support all 3mf format soon.
I have found a workaround!
Earlier, I used this site to fix stl to stl format:
http://modelrepair.azurewebsites.net
But now, this site redirected to
http://tools3d.azurewebsites.net
and I can download fixed model in 3mf format only. Unfortunatelly Cura 2.x.x does not support this 3mf file.
But I have found this site:
http://netfabb.azurewebsites.net
what is fix model from stl to stl, so I can load it in cura again.
I hope, this site will work for long time!
Edited by GuestDim3nsioneer 558
Cura does support 3mf in version 2.1.2. Just open it.
Cura 2.1.2 could not open 3mf (what fixed in http://tools3d.azurewebsites.net).
That was main issue what I mentioned.
You can try it yourself too!
Edited by Guest- 3 months later...
Problem still exist in Cura 2.3
I can not load 3mf file what are fixed on http://tools3d.azurewebsites.net. (I uploaded stl and downloaded 3mf)
Now I can not print anything :(
Does anybody experienced same problem? How do you solve it?
I've just tested this with the nightly build. It works fine there, so it should be fixed for 2.4
Edited by Guest- 2 months later...
Hi! I'm having an issue with Linux 16.04.1 LTS and Cura. I installed the PPA version that is available and it looks like it is going to start just fine. I get a splash screen and then it goes away and nothing happens. If I start it from command line it starts saying CuraEngineBackend.CuraEngineBackend.slic[152]: Starting slice job... and just keeps repeating that forever. Am I missing something? I'd love to be able to run Cura on my laptop.
Thanks!
Just download the appimage. The PPA is not officialy maintained by Ultimaker (it was created by someone that works for UM though).
- 2 weeks later...
Cura 2.4 starts to open then nothing. deleted all other cura off my machine. windows 10 64 bit
So tired 2.3.1 . Can't change nozzles unless you tell it + machine. doesn't like to lay stuff flat.
For fun tried to 2.4 to run and it did. weird.
Edited by Guest- 3 weeks later...
FYI - for a clean install you have to delete the appdata stuff also. Unfortunately. But the good news is you can just go wild and delete it all and restart cura and it just creates it again but properly. On windows go to:
C:\Users\XXXX\AppData\Local\cura
Where XXXX varies depending on your personal setup and login.
yellowshark 153
Ahem, back it up first otherwise you will lose any printer or settings profiles that you created with 2.4 beta and, I suspect but not sure, 2.3. Obviously if you are coming from 15.n or 2.1? not relevant
Any chance this info could be on the cura download page, or in the release notes:
" Warning CURA 2.x is like the highlander! There can be only one!" please do not try to run multiple copies of CURA 2.x on the same machine because they will behead each other and you will lose your settings"
- 1
Thanks @Peetersm, we are going to add this to the page / release notes. (I like the highlander reference.. that was a cool show But maybe we'll have to leave that out of the official mentioning )
yellowshark 153
Well actually not true, there can be more than 1 - as suggested by someone else recently - not my idea. I know because I tried and it worked. Create or use another existing account and install the 2nd version under the 2nd account, This provides a second separate appdata folder for Cura with all the settings.
No idea if you can actually have both Cura versions loaded at the same time.
2go 6
Same here. Models that took 1-3 seconds to slice using legacy Cura, now take 10-60 seconds. And a few models say 'preparing to slice' until I run out out of patience after 30 minutes.
