1. With the interface: pretty good!
We can even change the start/end gcode inside the IDE <3
Is it possible to set a "platform_texture" in this inst.cfg file?
Nope. Its a definition thing only.
Ok, my actual problem is after rotating the view several times, there's no indicator to know which side of the print area/printer is front or back...
If there's no way to add a custom texture, could you at least add a generic indicator so we know which side is which?
I found an issue though: the fan speed setting doesn't seem to be taken into account.
I created a new ABS material and set it to 0%, I still have fan enabled and 100% in the Print Setup tab.
This is due to our profile stack, which works as follows; user->quality_changes->quality->material->variant->definition
We first ask if the top (user) has the setting value. If not, we continue down. So if the quality sets a value (say fan speed) and material sets it as well, the one set by the quality is used.
We still need to tweak what we put in what profile.
I found the issue!
I did change the Profile Fan Speed at one point (and saved in Profile), then reverted it (and saved). However the Fan Speed "reset" is still writing the info into the Profile even if it's reseted to default (using the "i")!
cool_fan_speed = =100.0 if cool_fan_enabled else 0.0
It would be nice to automatically detect any given default setting and avoid writing the value into the profile to avoid this overriding another setting like Material.
Or maybe an ability to delete a profile setting from the Profiles Preferences? I had to manually open the profile.inst.cfg file to really remove the Fan Speed.
Also when clicking "Update profile with current settings", it's not refreshing the page, I believe the Current settings should move to Profile after click.
Same issue with "Discard..." which should delete the Current settings.
I also noticed that while the Layers view is way faster than 2.1, this eats CPU at breakfast!
I sometimes often to change the view and let Cura open while I print (from sd) and am wondering why my cpu fan is running full speed... Launch OSX's Activity Monitor->it's Cura!
Maybe you should pause some computations while Cura isn't the current active app?
30
24
19
18
Popular Days
Sep 2
50
Sep 21
16
Sep 3
15
Oct 19
8
DaHai8 30 posts
nallath 24 posts
ahoeben 19 posts
yellowshark 18 posts
Popular Days
Sep 2 2016
Sep 21 2016
Sep 3 2016
Oct 19 2016
Posted Images
DaHai8 74
Huston, We Have A Problem - I think.
I can't get any Supports to actually touch the build plate on this object (only if I turn on Raft can I get Supports on the first Object Print Layer.
I've not seen this behavior in other objects I've printed. And he's all BLUE is x-ray mode as well.
Bug or PEBKAC?
P.S: Really odd behavior on the first Support layer on the Raft: It did a retraction at the end of every line in the raft. Whenever it needed to change direction, it did a retraction, micro-move and then print. Needless to say, that first Support layer to FOREVER to print. Subsequent support layers are printing fine without any unnecessary retractions.
![5a332112c721f_SupportBugC.thumb.png.a5e9665b7044fe634e9d09365e68420a.png](//content.invisioncic.com/ultimake/monthly_2017_12/5a332112c721f_SupportBugC.thumb.png.a5e9665b7044fe634e9d09365e68420a.png)
Edited by GuestLink to post
