zerspaner_gerd 362
Found a mistake!
Have all the files from the "cura 2.1.3" in "C: \Users\name\AppData\Local\cura"
deleted, now it works.
Now I'll try with Dual Printing UM2
Found a mistake!
Anyone found a way to use dual extruders will a custom machine? I can't find anywhere to change the number of extruders
i completely lost my building platform / object when moving a bit to enthusiastic.
A center view on building plate button would help
Why no build for Linux?
how can we update materials, the "edit" button is greyed out when i have the PLA profile selected in the material preferences
many thanks
@nallath wrote this in another forum:
"There is no linux or win 32 build, because our build server decided to kill itself. We will release those next week. Let me know what you guys think."
What's that on the top right? I hover and no tags appear to show what the heck those are supposed to be
If you click the right one you get a printer status tab for USB printing from what i can see?
That's the other thing we had issues with. The editing / importing of materials is disabled for the moment being.
Idea for cura. the rotate option , you should be able use numbers for input.
Has someone managed to create a new profile with current settings under Cura 2.3 beta?
btw: Installation of the beta damaged part of my 2.1.3 profiles... :(
But: cool new features to test; one can now even change acceleration and jerk per print line type...
Edited by GuestWhat printer, what settings, what model?
Did you activate One at a time printing? From your very small screenshot crop, I can almost see that you are looking from the top of your buildplate. If you look at the buildplate more from the front, you will see that the available buildvolume has decreased. This is done because otherwise the gantry would collide with a previous print. You should have also gotten a message about this decrease in print volume height.
There seems to be a bug in the profile converter between 2.1 and 2.3 which causes a partly broken install. If you clear the data in AppData/Local/Cura, you will have a lot more functional Cura (but you will have to re-add your machine and settings).
Ultimaker 2 profile
Essentially, any model that, by default, does not fit the build plate seems to get this.
Once rotated to fit, the slicer progress bar seems to move. Whether it writes reliable gcode...I don't know.
Try a file that requires rotation to fit (I'm printing BB-8 parts, so everything is round/circular).
Cura 2.3 beta bug. The draft shield doesn't seem to work.
I see. The message needs some rewording, because what is "suitable" in this case? It should read something like "None of the models fit the build volume. Please scale or rotate your models to fit."
Please be more specific. Doesn't it print, or doesn't it provide enough protection against draft?
Yes, exactly.
Otherwise you have no idea if the work you do to fit the build plate is 'acknowledged' by Cura
It doesn't even try to print a draft shield. Tried twice .
I think the names of the new infill patterns tetrahedral and cubic should be just the other way round, so that tetrahedral is the one with triangles.
korneel 175
trying this one out.. however... Windows Smartscreen and Windows Defender feels this is a virus...
