On 1/5/2023 at 9:13 AM, dainon said:I use the S5 as a hobby; if someone's use case is similar to mine (i.e., small set of spools/colors), you can try this location for NFC tags and re-write to them when you replace a spool.
I 3D modeled an NFC tag holder (26mm square and staple shaped), then printed it in each filament. I attached the NFC tag (written per filament brand/type/color, using all the great information from this thread) to the inside left side of the material station bays. In this location, the NFC tags are recognized and updated. This works for all but the left most bay as it has a side wall there. For me, I used that bay for Ultimaker Breakaway filament, so it's not an issue.
Hey @dainon, I don't suppose you have a link (Amazon or otherwise) to the tags you used that you'd be willing to share. I've used a few different I've seen on Amazon and none of them seem to have worked for me. What's more the previously mentioned tags in the thread are no longer available on Amazon😕
Top Posters In This Topic
31
11
10
7
Popular Days
Nov 8
10
Mar 28
7
Jun 26
6
Nov 9
5
rachael7 31 posts
Hiabst 11 posts
Bunnyman21 10 posts
Monroe07 7 posts
Popular Days
Nov 8 2022
Mar 28 2024
Jun 26 2021
Nov 9 2022
Popular Posts
gandy
@gmeardi If you can love the solution depends on how much you are willing to stretch 'easy', so here we go. Before working with the Ultimaker S5, I've never really put my mind to NFC techn
Bunnyman21
@gandy I came across your example scripts for creating and writing spools while trying to write my own tags for some 3rd party spools. I just wanted to say the scripts worked really well! (I ended up
dainon
Posted Images
Monroe07 8
Through troubleshooting with you, It has been discovered that while you are using the most recent version of Cura (v5.3.0), Spoolmaker still requires something (or things) from Cura v5.0.0, or at least some other version of Cura earlier than v5.3.0. I've submitted an issue ticket on GitHub for the issue.
olivmath 1
Monroe is right, I had 5.3.0 and 5.2.1 version installed and nothing was opening/showing when clicking...
I just installed the 5.0.0 version and still not working, but at least I have an error window:
TheEngineerable 0
@Monroe07. How has the material station clone project gone? Do you have pictures of it?
