tinkergnome 918
There's no easy way (if any) to teach the UM3 your custom material. That's intended (AFAIK) and not a bug. The Cura Connect -Server uses this information to find a suitable printer for the print job. That's obviously not necessary, if you print from the USB-stick (that's why it does not complain in this case).
I know, that with Cura it's possible to create custom material profiles, but those are not very useful for the UM3 and the new firmware. Just choose generic PLA in Cura (but keep the current settings), if you want to send the job via network - and the printer is happy.
Dim3nsioneer 556
You may use the select material option on the um3 to set it to pla.
