2 minutes ago, Dim3nsioneer said:
The term "curvature" is not well-defined, so that is not the case. A large curvature could be a large radius. What you want is to have thinner layers when you have a surface with is very close to but not horizontal. That is it has a small angle (compared to horizontal). To get that defined you need thinner layers. You can see you get blue areas (thin layers) when you have features with near-horizontal angles. On the lower part of the benchy it is the top surface of the hull that induce thin layers then at the upper part of the door it is green because we only have the "vertical" part of the house there and then it becomes blue again when we approach the near horizontal part of the door opening and so on.
Top Posters In This Topic
20
14
10
5
Popular Days
Jan 30
19
Jan 26
13
Jan 24
10
Jan 23
9
kmanstudios 20 posts
ahoeben 14 posts
hoegge 10 posts
zerspaner_gerd 5 posts
Popular Days
Jan 30 2018
Jan 26 2018
Jan 24 2018
Jan 23 2018
Popular Posts
ahoeben
What, nothing about the improvements to manual supports and adjustment meshes? It is now much easier to load objects and mark them to be printed as supports, which is useful if Cura does n
SandervG
A new Ultimaker Cura is just lurking around the corner and we can’t wait to share what new features it will hold. Through this forum post I would like to share my most favorite new features with you a
itslow
How about ditching the perspective view and switching to an axonometric projection, or at least allowing the users to select one or the other? Engineering CAD is rarely, if ever, done in a perspectiv
Posted Images
hoegge 6
Does not help much, since there is no explanation there
