Thank you! The delay is because:
We have (yet another) engineering change, which will allow the standard
temp sensor to be much more easily recovered after it has been inserted, which is not always
the case in batch 1. The fault is a symptom of inconsistant diameter of the temp nozzle in
the crimp zone (not our fault).. We are also making a verification of the M3 fastening screw hole diameter holding the
cartridges, and changing the screw from umbraco style to phillips style.
A tiny, small screwdriver is included which is so small that it will help not overtightening the
cartridge screw.
110
109
71
62
Popular Days
Aug 18
22
Feb 19
22
Feb 20
19
Jan 24
19
swordriff 110 posts
gr5 109 posts
ultiarjan 71 posts
Anders Olsson 62 posts
Popular Days
Aug 18 2015
Feb 19 2015
Feb 20 2015
Jan 24 2015
Posted Images
gr5 2,192
I love having the transparency into your operation! I wish Ultimaker would share things like that - e.g. "all shipments will be delayed for at least a week because the current batch of heated bed thumb screws are defective and we are waiting on a new batch and we have to retrofit 300 printers once they arrive and are meanwhile still assembling". Or "serial numbers after XXXX now have a weaker spring (call it V3) and are set by default to the tightest setting.
