also because we were quite strict with reviewing
I think it is important to note that all code that goes into Cura gets reviewed. A feature as big a gcode viewing consists of a lot of code, so reviewing takes a while and the chances of changes being required before the code is accepted are high. The review was not delayed because the code came from AlephObjects.
- 1
nallath 1,123
Cura 2.5 can open g-code files. The feature was developed by AlephObjects (Lulzbot) and contributed back to us. Because they were working on it, we didn't build it. In the end they didn't met the deadline (also because we were quite strict with reviewing) for 2.4, so it was moved to 2.5
