Hiya and welcome.
I would be inclined to follow the blocked nozzle route. it may not be fully blocked but just old material layering around the inside. there are two things possibly three to try and resolve this issue.
1. poke the nozzle hole with a strand from a wire brush whilst it's hot and dialing the manual feed.
2. position the print head in the front right corner and heat up to 210 deg. using pliers force some cut off pla down the hot end. not too much force though as the axis may pop out. (just place the rods back in.)
3. replace the nozzle with a brand new one. after 2-3 years it may be due a change anyways. check out 3dsolex and give the ruby a try. pretty decent.
hope this helps
Bex
Torgeir 205
Hi kbtwining,
Welcome into the Ultimaker Community.
You made a very good description of your problem and it seems to be a known problem..
After reading through your post, we'll be very interested to know how is your PLA filament behaving after 3 years of storage? Does it become brittle and break off with a "snap"?
This is typically for old PLA that's been attracting some humidity over time.
What's happen is that the PLA tend to break inside the bowden tube, but still will be feed all the way through the tube and to the extruder. However; between the end of the bowden tube and the coupler (the white Teflon adapter you see inside the spring at the extruder), there is a little gap and at this place the filament tend to hook up preventing anymore feeding.
So, do not change anything but just have a new fresh roll of new PLA and do another try.
PLA have to be stored in a "controlled" environment; humidity as lo as possible, normally less than 17% humidity and in darkness. However, this is another topic..
PLA can be renewed to some level, -but again another topics.
Good Luck.
Thanks
Torgeir.
