ghostkeeper 105
The firmware delivered with Cura hasn't changed in 8 months (since Cura 2.6): https://github.com/Ultimaker/cura-binary-data/tree/master/cura/resources/firmware
The firmware repositories themselves did change, for instance this one: https://github.com/Ultimaker/Ultimaker2Marlin/commit/aa496a8f3b09ed7333b162deb21de5a9d154898a
However the changes made to the source code was only documentation so we didn't make a new build of the Ultimaker 2 firmware for that.
If there was a bug with the firmware of the Ultimaker 2, I wouldn't expect it to change with Cura 3.2. I would think that it was Cura at fault, so then it would appear in the g-code.
27
16
13
12
Popular Days
Feb 14
24
Feb 6
21
Feb 13
19
Feb 8
18
ahoeben 27 posts
SandervG 16 posts
Msuurmond 13 posts
VULCAN 12 posts
Popular Days
Feb 14 2018
Feb 6 2018
Feb 13 2018
Feb 8 2018
Popular Posts
kmanstudios
A) I have NO virus issue. You just ranted about your favorite anti-virus program. B)Yes, you have very poor communication skills and this is coming from someone with Asperger's. For instance you
SandervG
Ok, bye. Sorry guys for the inconvenience. Let's get back on topic.
ultiarjan
my 2 cents; Think it would be good to distinguish between the purpose of the video's. With a new release I would like a short snappy video quickly showing the new features, max a few minutes
Posted Images
burtoogle 516
Hi @Tafelspitz, I looked at the end of dowel2.gcode and dowel3_1.gcode and they look very similar. Neither contain any gcode to move the nozzle away from the surface at the end of the print. I would expect to see some end gcode that does that and other stuff like turning off the heat, fans, etc. I looked at some other people's UM3 gcode and a typical end sequence would be like this:
M204 S3000 M205 X20 Y20 M107 G91 ;Relative movement G0 F15000 X8.0 Z0.5 E-4.5 ;Wiping+material retraction G0 F10000 Z1.5 E4.5 ;Compensation for the retraction G90 ;Disable relative movement M82 ;absolute extrusion mode M104 S0 M104 T1 S0 ;End of Gcode
