I have some actual 3.0mm, +- .1 or so, and it gets a little tight in the bowden tube compared to the 2.85 stuff. But still works none the less. I usually measure with a caliper the diameter and plug the average into Cura because the actual diameter kinda varys wildly from manufacturers.
IRobertI 516
99.9% of the time "3mm" actually means "somewhere around 2.8-2.9mm" if you're looking at filament sold for use in 3d printers it will work just fine.
