Ultimaker Community of 3D Printing Experts
  • Sign Up
All Activity
This stream auto-updates
  1. Past hour
  2. What is the purpose of "Print thin walls". I've checked it's box and assumed it would print a wall thinner than my nozzle or line width. I hoped "Print thin walls" would print the .2mm walls as .5mm walls matching my line width.
  3. La machine fonctionne! J'ai pas mal galéré à cause d'une résistance chauffante défectueuse: j'ai l'impression qu'elle chauffe de façon irrégulière. Je l'ai remplacée et tout va bien pour l'instant. Je ne l'ai pas jetée, je la testerai de nouveau.
  4. Super, danke für den Hinweis! Da ich aktuell schon 30-40 Stunden Druckzeit für eines meiner "normalen" Modell habe, wäre das tatsächlich eine Katastrophe 😨 Dann wird es wohl doch bei meiner "Bastelei" bleiben... Bis es mal den "echten" Replikator gibt - am besten mit USB-Anschluss ans Hirn 🤑
  5. Hi Sander, what distance should I set between the cast aluminium bed and the plate on the S5? Or how can I measure 14 mm here? I can't insert a tool or calipers since there is an edge all around. See photo. Then I've had tremendous luck using the z-Offset plugin, even with "difficult" materials that used to lift off the build plate (here the proper adhesion medium did the trick, while squishing the material onto the plate did not). What setting do I need to change to battle the overextrusion of the initial layer, which leads to material build-up and bulging next to the nozzle path? Thanks for your help, Niklas
  6. Ah, OK, I missed the fact that you had a zillion bottom layers. No problem, happy printing!
  7. It does not change it but i think it was the "toplayers 0" " bottom layers 999999" setting that was recommended for printing tabletop minis that caused it. When i use a normal number there it works! Thank you for your support, i was stupid to not see that before but i thought it is the normal behaviour of "Spiralizing Outer Conture" that i saw not a failure from my other settings, i hope you understand.
  8. That gcode is weird, could it be the zoffset thingy that you are using is causing a problem?
  9. Today
  10. It is not flawed, despite your personal experience. Countless of users are happy with it and it works as it should. Otherwise it would be the only thing people talk about online, outside of the couple of reports and issues some people having with it. Because it does have some dependencies, like a clean print core and the correct tension on your build plate springs (14mm). For good adhesion the first layer needs to be squished onto the build plate. An unfortunate side affect is indeed elephant feet. This can be battled by adding a negative value in initial layer horizontal expansion. Hope this helps!
  11. Hello, here is the generated gcode. AG_Test.gcode And also the print profile if you need it. (it is in an .rar renamed to .zip to be able to upload it here) quality_changes.zip
  12. Strange, I don't have PETG, not on the S5, the S3 or the UM3. I am on the latest firmware wit all printers. That you have the material on the S3 is ok, as soon as you connect it with Cura the "missing" profiles are transferred. So in your case there must be a custom material with the material type PETG in Cura.
  13. Noch ein Hinweis zum Überlegen 🙂 Dein Beispiel oben lässt sich ziemlich sicher in einem drucken mit PVA als Supportmaterial, aber du darfst nicht vergessen, dass der Druck dann ewig dauern wird (sicher 4-5x so lange wie ein Einzeldruck) Bei jedem Layer wird gewechselt. Weiters hast du dann im inneren alles mit PVA voll, das dauert dann sicher 2-3 Tage bis sich das alles aufgelöst hat. Weiters ist PVA ein wirklich teures Material. Was ich damit sagen will, es hört sich alles schön an mit dem Dualdruck und so, aber in der Praxis ist dann doch nicht alles Gold was glänzt. Ich drucke persönlich nur jene Sachen mit PVA wenn es wirklich nicht anders geht, mir ist das einfach zu umständlich. Lieber drucke ich Einzelteile und Klebe dann als das ganze mit PVA zu drucken. Überlege dir also wirklich gut, ob du das brauchst und dann auch verwenden wirst. Ansonsten bleib beim UM2+, der im Single Druck nicht schlechter als die neueren ist, wenn nicht sogar besser.
  14. I would like to change a couple of the defaults within the PauseAtHeight.py file to numbers and/or text that I always use (Ex: default to "Layer" instead of "height", default idle temp to 205 instead of 0 - that sort of thing). (If I'm adding stripes to a print and pausing 5 or 6 times to change colors it would be nice if I didn't have to change the same lines over and over.) I can copy the file, rename it, and make my changes but it isn't part of the Cura install. Is there a relatively painless way for me to add it?
  15. I see PETG Generic in both my s5 and my s3, The s5 i might have once added a PETG profile from the market place to Cura, but that's not something i have done in the limited time i have had the s3 and the only profiles from market place i have added to cura now days are ColorFabb wood fill, color on demand pla and XT-CF20
  16. Thanks for your input. I've never seen this tool to set the gap before, shouldn't it be included with new machines if this distance is that important? As I've mentioned, I've never been able to get a successful first layer without tweaking the G-Code via the Z-offset plugin. That's my whole point - to me, a successful first layer means that it looks good and doesn't have elephant's foot and over extrusion. Adhesion shouldn't be achieved by forcefully squishing the filament to the print bed, but by using suitable measures such as brim, raft, adhesion medium and bed temperature (all of which usually work! If they don't, forcing the material onto the glass plate won't either IMO). And for what it's worth, a "slight touch" shouldn't make the x-y gantry flex. In short; the UM auto bed leveling is flawed. Change my mind. PS: I don't have bad intentions or a grudge against UM, but I've never read an answer to this problem that addressed the concerns directly, only hints that I've followed in the first place (clean nozzle etc).
  17. Hallo, mein UM2 hat heute Nacht irgendwann aus einem unbekannten Grund während des Drucks das Filament entweder ausgeworfen, oder in die falsche Richtung geschoben. Der Druck selbst ist noch gelaufen wie er es sollte, nur eben ohne Material. Das ganze ist vor einiger Zeit schon mal passiert aber mit anderen Einstellungen. Hat jemand auch irgendwann diesen fehler gehabt oder kann sagen woran es liegen könnte? Es handelt sich um einen UM2 erste Generation mit Bondtech Extruder, Olsson Block und Tinker Firmware. Die Hardware und Software ist in diesem Zustand seit mindestens 2 Jahren. Für die Einstellungen hab ich noch 3mf Datei im Anhang, es handelt sich aber nicht um die Datei bei der der Fehler auftrat. danke im Voraus UM2WOB_test.3mf
  18. Danke an alle! Mal überlegen was ich nun mache..
  19. I suppose the key lies in nuance. They should touch, and the bed should slightly push the nozzle up to perform the measurement. It is possible that it pushed the bed down all so slightly at the end of its measurement. But it is not supposed to push it down, which is what I understood from your initial message. I believe the space between the Z stage and the heated bed is suppose to be 14mm ideally. Perhaps you could check this too @neute? We do not allow active leveling to be disabled on the Ultimaker S5 because the bed is significantly larger than an Ultimaker S3 or Ultimaker 3. This means that a minor offset can go by unnoticed on an Ultimaker (S)3, but can compromise bed adhesion on an Ultimaker S5. And we know that a successful first layer is key to a good print. It shouldn't be a pain and you shouldn't resort to Cura to work around it. Make sure the bed springs are at the correct tension and your print cores are clean. You can find more tips via this link, via our partner in the us FBRC8.
  20. Thanks for the file, unfortunately, it uses an unknown printer type so I cannot load the project, just the models. With the project, I can't see what settings you are using. Anyway, I sliced the model using my standard setup and the spiralization looks OK. Could you please attach the gcode file? That is almost as useful as the project file, thanks.
  21. Thanks, I was browsing there but couldnt see the forrest because of all the trees 😉 Found it now
  22. Hallo Helmut, mit dem Bild, deinen Informationen und Beobachtungen, bleibt theoretisch eine Ursache. Ja, die Lötzin-Reste auf der Platine können die Ursache sein. Die sind auch an den Pads der Sensoren zu erkennen und von daher keine mitbringsel eines Kurzschlusses. Herstellungsfehler am Solex Core: Zu viel Lötpaste an den falschen stellen. Der Reflow tat das übrige. Geprüft hat es anscheinend niemand. Beim Einlegen verbiegen diese Lötzin-Reste die PINs auf der Hotend-Platine. Es kommt zum Kurzschluss. Dazu muss man den Core vermutlich nur etwas schräg (nicht falsch) einführen damit es raucht. Wobei du auch Glück hast das es gleich geraucht hat. Die Cores hätten dir auch nur die Pins der Platine verbiegen können. Dann hätte es irgendwann andermal mit einem anderen Core geraucht. Dann die Ursache zu finden wäre umständlicher gewesen. Das die Cores vom Anwender falsch eingesetzt werden könnten ist an den Haaren herbeigezogen. Sagen wir so. Du kommst vermutlich schadfrei aus der Sache raus. Der Händler/Hersteller ist aus rechtlichen Gründen etwas erfinderisch mit den Argumenten (oder schlicht charakterlich Flexibel). Also lehne dich zurück und lasse machen. Viel Erfolg!
  23. The fix that @burtoogle made for the OP has been deemed low risk enough that we'll try to get it in 4.7, a beta of which should be out relatively shortly.
  24. I have only touched the screws during the manual bed leveling procedure, meaning that I moved each screw only a maximum of 1 mm. So, you say that it is okay for the nozzle to touch the bed and pressing it down? SandervG said otherwise.. By all means! I must admit, the first layer (and first few layers) on the UMS5 is (are) a pain indeed. I have been playing with the initial layer line width in cura, which helps only slightly. This is not an issue with my Prusa MK3S, which has auto bed leveling enabled too...
  25. Hi, if I may board this thread shamelessly - if I understand the autoleveling behavior correctly, it is flawed because of some assumptions that result in an inconsistent result, that is also consistently too close (this can be measured by aborting a print after the first layer or measuring the brim of the part and comparing it to "initial layer height"). Please correct me if I'm wrong here! (and please tell my why!) My understanding of the autoleveling is mostly like @Smithy describes; the bed creeps up to the nozzle, and as soon as the nozzle hits the bed, the distance between nozzle and bed doesn't change any more and this is measured by the sensor. In an ideal world, this would mean that the nozzle, which is held down by a spring in the printcore to ensure perfect position, gets pushed upward against the spring force. However, since nothing is ideal, not only the nozzle gets pushed in, but the bed flexes (due to the cantilever design), the x-y rods flex upward (visibly!), and maybe even the bed springs compress. If my assessment of the system is correct, this introduces a significant error. I've noticed this with one S5 and one S3 that I have access to. The solution to gain a first layer that is consistent in height with what I set in Cura, is to use the Z-offset plugin at 0,1 mm extra height. Problem solved (albeit in a quick & dirty way, I shouldn't have to do this - this shouldn't be an issue in the first place). However, and this is why I mentioned "inconsistent", I also often get height differences between the two nozzles that sometimes exceed one layer height (note that the printer is happy about this, no "height difference exceeds realistic values" error). Resulting, of course, in filament being squished into the former layer of support material etc. Keeping the nozzles meticulously clean only helps so far. Also it seems as if the problem gets worse with 3rd party cores, a.k.a 3DSolex, which supports my theory that the spring in the printcore plays a role. On the UM3, all of these issues were resolved by disabling autoleveling - unfortunately, UM decided that we shouldn't have this option for the newer machines. If there is something wrong with my machines or if I had a misassumption, please let me know! Best regards, Niklas
  26. Ok, thank you. Here is the file from Cura. (I made the model in fusion 360 and exported it in cura first then saved from cura as you wrote me) Test.3mf
  1. Load more activity
