So depending on the inconsistency of the current it may lead to a missing step down the line?
Like if it does 0.8 instead of 1 for 5 times, you are missing a full step?
There is probably plenty of which I don't understand, but what struck me as weird (and maybe it is not weird at all so that is why I'm asking) is that he said it also happened on his home build 3D Printer. So that leads me to think it is a stepper motor problem? Or stepper driver?
But it can be fixed by whatever he added to his electronics, right?
So initially I thought hm, maybe we missed this small thing in our electronics design, but if it is in more printers, and can be 'relatively easy fixed', how come the error still exists?
Doesn't really make sense that is why I think it is more complicated then I just wrote down here.
Top Posters In This Topic
50
38
38
38
Popular Days
Jun 17
24
Jun 18
22
Jun 15
18
May 27
16
DrR1pper 50 posts
gr5 38 posts
Torgeir 38 posts
cloakfiend 38 posts
Popular Days
Jun 17 2015
Jun 18 2015
Jun 15 2015
May 27 2016
Popular Posts
gr5
Not so fast Martijn! This is not solved yet! I looked at the gcodes for the lines that get those diagonal lines on benchy. To the left of the arch (near the top of the arch) a typical movement in X
JohnInOttawa
This is of interest to me, I have both an Ultimaker Original and UM3, will certainly mod the Original, just need to decide if I will mod the UM3 as well. Shout out to gr5 - great service,
ArrMack
Hi, the link to this is dead. Any chance you could add an updated link?
Posted Images
gr5 1,506
Hi @SandervG. Microstepping is very complicated even for an electrical engineer like myself. You have 2 sine waves going to the different halves of the stepper and they are phase shifted but for some reason I don't understand the amount of current going to each half is different and changes as the phase changes. Because the current/power is changing evidently some of the step positions are using less current - so low that it's not enough power to move the stepper that additional microstep. This is what I read but doesn't agree with other information I read about how it all works. Anyway then what happens is on the 17th step the power is back up and finally the stepper moves again. As a result only 14 or 15 of the 16 microsteps actually work and when you hit those "weak" steps you get a bump in the part (the zebra stripes).
Of course the bump is so tiny it's hard to see on a low quality printer.
But if you have almost (but not quite) vertical walls you can see the bumps as lines.
DrR1pper 4
An observation that may or may not be useful here, i've since seen in person benchy prints on both a zortrax and um2+ at different z angles on the print bed and i could not see any zebra stripes on the zortrax printed benchy.
Edited by GuestLink to post
