Ultimaker Community of 3D Printing Experts
Cura 15.10 Open Beta
Posted · Cura 15.10 Open Beta
Calling engine with: ['/Applications/Cura 15.09.83.app/Contents/MacOS/CuraEngine', 'connect', '127.0.0.1:49675', '-j', '/Applications/Cura 15.09.83.app/Contents/Resources/cura/resources/machines/fdmprinter.json', '-vv']
Cura_SteamEngine version DEV
Copyright © 2014 David Braam
This program is free software: you can redistribute it and/or modify
it under the terms of the GNU Affero General Public License as published by
the Free Software Foundation, either version 3 of the License, or
(at your option) any later version.
This program is distributed in the hope that it will be useful,
but WITHOUT ANY WARRANTY; without even the implied warranty of
MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
GNU Affero General Public License for more details.
You should have received a copy of the GNU Affero General Public License
along with this program. If not, see .
Loading polygon setting machine_disallowed_areas not implemented...
Unrecognized data type in JSON: machine_platform_offset has type array
Loading polygon setting machine_head_polygon not implemented...
Loading polygon setting machine_head_with_fans_polygon not implemented...
    • Replies 278
    • Created
    • Last Reply
    Top Posters In This Topic
    Posted Images
    22-09-15 14:49:42,351 Cura[534]: 2015-09-22 14:49:42,351 - INFO - Loaded plugin ConsoleLogger
    22-09-15 14:49:42,371 Cura[534]: 2015-09-22 14:49:42,370 - INFO - Loaded plugin OBJReader
    22-09-15 14:49:42,381 Cura[534]: 2015-09-22 14:49:42,380 - INFO - Loaded plugin OBJWriter
    22-09-15 14:49:42,392 Cura[534]: 2015-09-22 14:49:42,391 - INFO - Loaded plugin STLReader
    22-09-15 14:49:42,403 Cura[534]: 2015-09-22 14:49:42,402 - INFO - Loaded plugin STLWriter
    22-09-15 14:49:42,414 Cura[534]: 2015-09-22 14:49:42,413 - INFO - Loaded plugin FileLogger
    22-09-15 14:49:42,444 Cura[534]: 2015-09-22 14:49:42,444 - INFO - Loaded plugin LocalFileOutputDevice
    22-09-15 14:49:42,483 Cura[534]: 2015-09-22 14:49:42,482 - INFO - Loaded plugin CameraTool
    22-09-15 14:49:42,504 Cura[534]: 2015-09-22 14:49:42,503 - INFO - Loaded plugin MirrorTool
    22-09-15 14:49:42,543 Cura[534]: 2015-09-22 14:49:42,542 - INFO - Loaded plugin PerObjectSettingsTool
    22-09-15 14:49:42,597 Cura[534]: 2015-09-22 14:49:42,596 - INFO - Loaded plugin RotateTool
    22-09-15 14:49:42,650 Cura[534]: 2015-09-22 14:49:42,649 - INFO - Loaded plugin ScaleTool
    22-09-15 14:49:42,676 Cura[534]: 2015-09-22 14:49:42,675 - INFO - Loaded plugin SelectionTool
    22-09-15 14:49:42,696 Cura[534]: 2015-09-22 14:49:42,695 - INFO - Loaded plugin TranslateTool
    22-09-15 14:49:42,814 Cura[534]: 2015-09-22 14:49:42,813 - INFO - Checking for new version of cura
    22-09-15 14:49:42,814 Cura[534]: 2015-09-22 14:49:42,813 - INFO - Loaded plugin UpdateChecker
    22-09-15 14:49:42,855 Cura[534]: 2015-09-22 14:49:42,854 - INFO - Loaded plugin MeshView
    22-09-15 14:49:42,873 Cura[534]: 2015-09-22 14:49:42,872 - INFO - Loaded plugin WireframeView
    22-09-15 14:49:42,930 Cura[534]: 2015-09-22 14:49:42,929 - INFO - Loaded plugin 3MFReader
    22-09-15 14:49:42,951 Cura[534]: 2015-09-22 14:49:42,950 - INFO - Loaded plugin ChangeLogPlugin
    22-09-15 14:49:43,211 Cura[534]: 2015-09-22 14:49:43,211 - INFO - Loaded plugin CuraEngineBackend
    22-09-15 14:49:43,229 Cura[534]: 2015-09-22 14:49:43,228 - INFO - Loaded plugin GCodeWriter
    22-09-15 14:49:43,275 Cura[534]: 2015-09-22 14:49:43,275 - INFO - Loaded plugin LayerView
    22-09-15 14:49:43,309 Cura[534]: 2015-09-22 14:49:43,308 - INFO - Loaded plugin PostProcessingPlugin
    22-09-15 14:49:43,349 Cura[534]: 2015-09-22 14:49:43,348 - INFO - Loaded plugin RemovableDriveOutputDevice
    22-09-15 14:49:43,393 Cura[534]: 2015-09-22 14:49:43,392 - INFO - Loaded plugin SliceInfoPlugin
    22-09-15 14:49:43,584 Cura[534]: 2015-09-22 14:49:43,583 - INFO - Loaded plugin USBPrinting
    22-09-15 14:49:43,630 Cura[534]: 2015-09-22 14:49:43,629 - INFO - Started engine process: /Applications/Cura 15.09.83.app/Contents/MacOS/CuraEngine
    22-09-15 14:49:43,924 Cura[534]: 2015-09-22 14:49:43,923 - DEBUG - Setting value of setting infill_sparse_density to 5
    22-09-15 14:49:43,924 Cura[534]: 2015-09-22 14:49:43,923 - DEBUG - Setting value of setting shell_thickness to False
    22-09-15 14:49:43,925 Cura[534]: 2015-09-22 14:49:43,924 - DEBUG - Setting value of setting support_connect_zigzags to True
    22-09-15 14:49:43,925 Cura[534]: 2015-09-22 14:49:43,925 - DEBUG - Setting value of setting support_type to buildplate
    22-09-15 14:49:43,926 Cura[534]: 2015-09-22 14:49:43,925 - DEBUG - Setting value of setting top_bottom_pattern to concentric
    22-09-15 14:49:43,926 Cura[534]: 2015-09-22 14:49:43,925 - DEBUG - Setting value of setting support_pattern to grid
    22-09-15 14:49:43,927 Cura[534]: 2015-09-22 14:49:43,926 - DEBUG - Setting value of setting skin_alternate_rotation to False
    22-09-15 14:49:43,930 Cura[534]: 2015-09-22 14:49:43,929 - DEBUG - Setting value of setting infill_sparse_density to 50
    22-09-15 14:49:43,930 Cura[534]: 2015-09-22 14:49:43,930 - DEBUG - Setting value of setting meshfix_extensive_stitching to False
    22-09-15 14:49:43,931 Cura[534]: 2015-09-22 14:49:43,930 - DEBUG - Setting value of setting print_sequence to one_at_a_time
    22-09-15 14:49:43,931 Cura[534]: 2015-09-22 14:49:43,931 - DEBUG - Setting value of setting magic_mesh_surface_mode to surface
    22-09-15 14:49:43,932 Cura[534]: 2015-09-22 14:49:43,931 - DEBUG - Setting value of setting meshfix_union_all_remove_holes to False
    22-09-15 14:49:43,932 Cura[534]: 2015-09-22 14:49:43,932 - DEBUG - Setting value of setting skirt_line_count to True
    22-09-15 14:49:43,933 Cura[534]: 2015-09-22 14:49:43,932 - DEBUG - Setting value of setting meshfix_keep_open_polygons to False
    22-09-15 14:49:43,936 Cura[534]: 2015-09-22 14:49:43,935 - DEBUG - Setting value of setting layer_height to 0.06
    22-09-15 14:49:43,939 Cura[534]: 2015-09-22 14:49:43,938 - DEBUG - Setting value of setting layer_height to 0.1
    22-09-15 14:49:43,948 Cura[534]: 2015-09-22 14:49:43,947 - DEBUG - Backend connected on port 49674
    22-09-15 14:49:43,971 Cura[534]: 2015-09-22 14:49:43,971 - DEBUG - Setting active view to MeshView
    22-09-15 14:49:44,159 Cura[534]: 2015-09-22 14:49:44,159 - DEBUG - Calculating normals took 0.002402067184448242 seconds
    22-09-15 14:49:44,160 Cura[534]: 2015-09-22 14:49:44,159 - DEBUG - Loaded a mesh with 10452 vertices
    22-09-15 14:49:45,979 Cura[534]: 2015-09-22 14:49:45,978 - DEBUG - Loaded theme /Applications/Cura 15.09.83.app/Contents/Resources/cura/resources/themes/cura
    22-09-15 14:49:52,231 Cura[534]: file:///Applications/Cura 15.09.83.app/Contents/Resources/qml/QtQuick/Controls/Menu.qml:146: TypeError: Cannot read property '__contentItem' of null
    22-09-15 14:49:52,232 Cura[534]: file:///Applications/Cura 15.09.83.app/Contents/Resources/qml/QtQuick/Controls/Menu.qml:146: TypeError: Cannot read property '__contentItem' of null
    22-09-15 14:49:52,232 Cura[534]: file:///Applications/Cura 15.09.83.app/Contents/Resources/cura/resources/qml/SidebarHeader.qml:85:31: Unable to assign [undefined] to int
    22-09-15 14:49:52,286 Cura[534]: file:///Applications/Cura 15.09.83.app/Contents/Resources/qml/QtQuick/Controls/Styles/Base/ButtonStyle.qml:154: TypeError: Cannot read property of null
    22-09-15 14:49:52,294 Cura[534]: file:///Applications/Cura 15.09.83.app/Contents/Resources/qml/QtQuick/Controls/Styles/Base/ButtonStyle.qml:154: TypeError: Cannot read property of null
    22-09-15 14:49:52,306 Cura[534]: file:///Applications/Cura 15.09.83.app/Contents/Resources/qml/QtQuick/Controls/Styles/Base/ButtonStyle.qml:154: TypeError: Cannot read property of null
    22-09-15 14:49:52,311 Cura[534]: file:///Applications/Cura 15.09.83.app/Contents/Resources/qml/QtQuick/Controls/Styles/Base/ButtonStyle.qml:154: TypeError: Cannot read property of null
    22-09-15 14:49:52,320 Cura[534]: file:///Applications/Cura 15.09.83.app/Contents/Resources/qml/QtQuick/Controls/Styles/Base/ButtonStyle.qml:154: TypeError: Cannot read property of null
    22-09-15 14:49:52,328 Cura[534]: file:///Applications/Cura 15.09.83.app/Contents/Resources/qml/QtQuick/Controls/Styles/Base/ButtonStyle.qml:154: TypeError: Cannot read property of null
    22-09-15 14:49:52,336 Cura[534]: file:///Applications/Cura 15.09.83.app/Contents/Resources/qml/QtQuick/Controls/Styles/Base/ButtonStyle.qml:154: TypeError: Cannot read property of null
    22-09-15 14:49:52,341 Cura[534]: file:///Applications/Cura 15.09.83.app/Contents/Resources/qml/QtQuick/Controls/Styles/Base/ButtonStyle.qml:154: TypeError: Cannot read property of null
    22-09-15 14:49:52,355 Cura[534]: file:///Applications/Cura 15.09.83.app/Contents/Resources/qml/QtQuick/Controls/Styles/Base/ButtonStyle.qml:154: TypeError: Cannot read property of null
    22-09-15 14:49:52,371 Cura[534]: file:///Applications/Cura 15.09.83.app/Contents/Resources/qml/QtQuick/Controls/Styles/Base/ButtonStyle.qml:154: TypeError: Cannot read property of null
    22-09-15 14:49:52,373 Cura[534]: file:///Applications/Cura 15.09.83.app/Contents/Resources/qml/QtQuick/Controls/Styles/Base/ButtonStyle.qml:154: TypeError: Cannot read property of null
    22-09-15 14:49:52,423 Cura[534]: 2015-09-22 14:49:52,422 - DEBUG - Preparing to send slice data to engine.
    22-09-15 14:50:01,814 Cura[534]: 2015-09-22 14:50:01,813 - DEBUG - Preparing to send slice data to engine.
    22-09-15 14:50:03,739 Cura[534]: QFileInfo::absolutePath: Constructed with empty filename
    22-09-15 14:50:04,355 Cura[534]: assertion failed: 14F27: libxpc.dylib + 62447 [5C829202-962E-3744-8B50-00D38CC88E84]: 0x89
    22-09-15 14:50:07,928 Cura[534]: 2015-09-22 14:50:07,927 - DEBUG - Calculating normals took 0.00032210350036621094 seconds
    22-09-15 14:50:07,928 Cura[534]: 2015-09-22 14:50:07,928 - DEBUG - Loaded a mesh with 72 vertices
    22-09-15 14:50:07,932 Cura[534]: 2015-09-22 14:50:07,932 - DEBUG - Loading mesh took 0.10672307014465332 seconds
    22-09-15 14:50:08,621 Cura[534]: 2015-09-22 14:50:08,620 - DEBUG - Preparing to send slice data to engine.
    22-09-15 14:50:08,642 Cura[534]: 2015-09-22 14:50:08,641 - DEBUG - Sending data to engine for slicing.
    22-09-15 14:50:14,422 Cura[534]: 2015-09-22 14:50:14,421 - DEBUG - Setting active view to LayerView
    22-09-15 14:50:22,495 Cura[534]: 2015-09-22 14:50:22,494 - DEBUG - Setting value of setting infill_sparse_density to 2
    22-09-15 14:50:22,498 Cura[534]: 2015-09-22 14:50:22,497 - DEBUG - Setting value of setting infill_sparse_density to 2
    22-09-15 14:50:22,498 Cura[534]: file:///Applications/Cura 15.09.83.app/Contents/Resources/qml/UM/Settings/SettingView.qml:119:35: QML SettingItem: Binding loop detected for property "value"
    22-09-15 14:50:22,499 Cura[534]: file:///Applications/Cura 15.09.83.app/Contents/Resources/qml/UM/Settings/SettingView.qml:119:35: QML SettingItem: Binding loop detected for property "value"
    22-09-15 14:50:24,354 Cura[534]: 2015-09-22 14:50:24,353 - DEBUG - Preparing to send slice data to engine.
    22-09-15 14:50:24,356 Cura[534]: 2015-09-22 14:50:24,356 - WARNING - The setting skirt_line_count has an invalid value of True
    22-09-15 14:50:24,357 Cura[534]: 2015-09-22 14:50:24,356 - WARNING - Profile has error values. Aborting slicing
    22-09-15 14:50:26,894 Cura[534]: 2015-09-22 14:50:26,893 - DEBUG - Setting value of setting infill_sparse_density to
    22-09-15 14:50:27,423 Cura[534]: 2015-09-22 14:50:27,422 - DEBUG - Preparing to send slice data to engine.
    22-09-15 14:50:27,426 Cura[534]: 2015-09-22 14:50:27,425 - WARNING - The setting skirt_line_count has an invalid value of True
    22-09-15 14:50:27,426 Cura[534]: 2015-09-22 14:50:27,426 - WARNING - Profile has error values. Aborting slicing
    22-09-15 14:50:28,214 Cura[534]: 2015-09-22 14:50:28,213 - DEBUG - Setting value of setting infill_sparse_density to 5
    22-09-15 14:50:28,669 Cura[534]: 2015-09-22 14:50:28,669 - DEBUG - Setting value of setting infill_sparse_density to 50
    22-09-15 14:50:29,150 Cura[534]: 2015-09-22 14:50:29,149 - DEBUG - Preparing to send slice data to engine.
    22-09-15 14:50:29,154 Cura[534]: 2015-09-22 14:50:29,153 - WARNING - The setting skirt_line_count has an invalid value of True
    22-09-15 14:50:29,155 Cura[534]: 2015-09-22 14:50:29,154 - WARNING - Profile has error values. Aborting slicing
    I saw this line and looked at it, skirt was set to 1, which is apparently the default because I started with a global normal profile. Reset the skirt, but noticed that it stayed at 1, although the preview shows 3.
    Threw away the customized profiles, and now it is gone..:)
    Changing the skirt lines to 1 or 2 doesn't change the preview, it always displays 3.
    duh.. this is because of the skirt length....
    But even the value True should be converted to 1, which is a valid setting. I've even changed the machine default to True and couldn't get it to crash.
    Does installing this Beta modify something on the "official" version if this is installed on the same machine? - I am printing something sliced with 15.04, and I feel that the infills gets printet much faster than before, to the point that the extruding cant extrude fast enough, so the infills gets a bitt splattery.
    No you can work with different versions of Cura on the same machine.
    It probably comes from the way you sliced it
    The old Cura (up to 15.04) and the new Cura (15.06 and beyond) do not share any settings as far as I know, so you should be able to run them side-by-side and one does not affect the other.
    However, 15.06 and the new betas share the same settings files, and there could be some incompatibilities between these versions.
    Thanks, no new methods of slicing here, maybe I just remember it wrong. Is there anywhere to access the different speeds: innfill/ perimeter etc.
    You mean in the new Cura? Ooh yeah... Check out the "Settings" section in the Preferences! There are LOTS of settings that you can fiddle with.
    In 15.04 you can access the different speeds by going in expert mode.
    In the advanced tab.
    The quickprint profiles have an infill speed that is quite high and can cause underextrusion
    I am using the beta and 15.04 on Win10 in parallel and wanted to chime in :-)
    I like the new UI and think the slicer in the new version performs better with regards to processing speed. I have not encountered any crashes or obvious bugs yet.
    When I tested an earlier beta (believe it was 15.06), I missed the "print one at a time" vs. "print all at once" setting as well as print profiles - I was very pleased to find these in 15.10.
    Unfortunately the print profile file format seems to be incompatible between 15.04 and 15.10 - will you provide at least an import filter for earlier version profiles?
    I use my UM2 with many different materials and have created about 20 profiles for different filaments, part sizes, accuracy and mechanical strength needed, etc.
    It would be really annoying to recreate all those settings in Cura 15.10.
    Thanks!
    It set skirt line count to True, which it finds invalid (as it needs to be a number!). I'm completely unable to reproduce the error in any way :S
    Could you delete your profile and try again?
    The same error happened to me right now with latest 15.10. Normal quality profile was selected and it sliced the model well. But after the support disabling the error appeared.
    Here is the log:
    2015-09-23 16:06:13,346 - DEBUG - Preparing to send slice data to engine.2015-09-23 16:06:13,431 - DEBUG - Sending data to engine for slicing.2015-09-23 16:07:02,636 - DEBUG - Setting value of setting support_enable to False2015-09-23 16:07:03,138 - DEBUG - Preparing to send slice data to engine.2015-09-23 16:07:03,139 - WARNING - The setting skirt_line_count has an invalid value of True2015-09-23 16:07:03,139 - WARNING - Profile has error values. Aborting slicing2015-09-23 16:07:28,400 - DEBUG - Setting value of setting support_enable to True
    Somehow it convert all values which has value 1 to True. When I set the skirt_line_count to 2, skirt_line_count pass the profile validation. But then, it hangs on another value with same error:
    2015-09-23 16:17:44,310 - WARNING - The setting material_print_temperature has an invalid value of True
    OS:Fedora 21
    Cura 15.10 from the source
    With version .83 I have a lot of strings and almost no retraction! tried version .80 with the same model and same settings and print as wanted.
    I installed 15.09.82 and 15.09.83. Both didn't start up at all.
    15.09.80 and 15.09.81 DO start up.
    I'm running on Ubuntu 15.04
    Can confirm this for the latest version, this is the error message from the console:
    Traceback (most recent call last): File "/usr/bin/cura_app. py", line 14, in    import cura. CuraApplication File "/usr/lib/python3/dist-packages/cura/CuraApplication. py", line 9, in    from OpenGL import GLImportError: No module named 'OpenGL'
    (Note: added blanks above to avoid the tagging as "url")
    I installed opengl and upgraded to 15.09.84. Now it working again!
    Hi! beside all the above reported isues, I like the design and functionallity of the 15.09.84 beta.
    Nevertheless, when will dual extrusion be supported??
    I have a UMO with customized dual extrusion head and customized fans so I have to mod the settings there too...
    @Marit, nallath, could you please give me some hints on this???
    There is no easy way to get the dual extrusion to work with 15.9.xx or 15.10 yet. It should be supported for 16.1 (which will be released in about 3 months).
    You can change the head size in the new version; you have a -lot- more options there compared to the old Cura. The old Cura simply assumed your head shape was a rectangle, where the new cura allows you to use polygons.
    • Like 2
    Great news - thank you !!
    So I stay with my modified 15.04 until 16.1 :-)
    Would be great to have a simulation with a moving head out of this additional informaiton from the head dimensions too... :-)
    what are the improvements?
    • 23 Visiting our virtual showroom
      1. 1. Have you visited our virtual showroom before?
        • Yes
        • No
      2. 2. If yes - what content did you find most interesting?
        • Information about Ultimaker ecosystem
        • Applications & application stories
        • Customer success stories
        • Webinar sessions
        • Material wall & ecosystem partners
        • New product introduction; software subscription plans
      3. 3. What of the below would make you consider visiting (again)?
        • New Live Ultimaker Webinar streams
        • ‘Ask Me Anything’ with industry experts or Ultimaker staff via main stage and public chat
        • New customer success stories
        • New applications
        • Presentations/news from ecosystem partners
        • Opportunity to meet representatives for an interactive tour
        • Helpful videos like Software tutorials
        • Other; leave input in a comment below!
      • Ultimaker turns 10: A look back
        Ultimaker is turning 10 years old and that means it is story telling time! We'll explore 2010-2014, traveling through the evolution of the business from the Protobox and Ultimaker Original, to the major leaps forward with the Ultimaker 2 and Ultimaker 3.
      • Ultimaker Transformation Summit
        Visit our virtual showroom and learn more about the Ultimaker ecosystem!
        • 14 replies
      • New here? Register your Ultimaker for free 3D printer onboarding course
