I use the original ultimate pva and settings.... if i print much slower it works better...
fbrc8-erin 234
Is the glass clean when you start? What about the tip of the nozzle? If you've got filament hanging off the end it can throw off the active leveling.
What are you using as the second material?
It doesn't mater what is the second material...
yes, the glass is clean. active leveling works good and there is no dirt on the nozzle. the pva doesn't stick on the glass if the nozzle put a new line of pea across an existing line... so if there are only lines of pva and no crossings it works better... but sooner or later there is a crossing and the new line pulls the existing lines away
markus
fbrc8-erin 234
Have you tried putting a wash of glue on the bed? I usually use a few swipes of Uhu glue on the bed, and then a wet paper towel to thin it out until there is only a thin film on the bed (no lumps). Any excess water should dry as the bed heats.
Hi Markus,
When looking at this first layer of PVA (the second extruder) it seems to be to high above the bed. I.E. it is not squeezed to the bed, I'd assume it should look a little "flatten out" looking. The skirt (PVA) looks to be "kind" of good, -so could it be something about height "now and then" different when switching head to number two?
Anyway, good luck.
Thanks.
Torgeir.
Dim3nsioneer 528
Dissolve that printed PVA in water and smear the solution with a clean cloth onto the glass, then let it dry by heating up the bed. PVA, PLA and Nylon should then stick like nothing to the glass.
... or apply a solution of 1/3 wood glue (is also made of PVA) and 2/3 water if you dont want to dissolve your expensive PVA :-)
tinkergnome 834
Well, you can still re-use the PVA - after it has been printed - for this purpose, right? (ask, how I know...)
Additional hints regarding the original question: you can try the following:
- increase the printing temperature for PVA a bit
- increase the feeder tension (approx. to 70% of the max. position)
- increase the flow rate (try 120%)
All three things can be tuned during printing. You'll see the difference. +5°C and a good feeder tension worked for me. Increasing the flow is the emergency solution.
reuse - sure... never thouht about it as its mostly run directly through the sink...
PVA should stick to the buildplate just fine. Really. With the default profiles.
I advise against playing with the settings. The settings in the profiles have been tested very well, and perform robust if your machine is in order.
Have you had any incidents with PVA with the BB nozzle? I mean, a period where there was little or no flow, and the nozzle was hot?
PVA deteriorates quickly, and your BB print core can be partly blocked. That gives underextrusion, which hurts your first layer.
I notice that the support is printed with squares, while I think the default in all profiles is "triangles". So my guess is that you don't use the default settings.
I hade the same problem when I had grinding on the PVA feeder on the back... check for any marks of grinding on the filament.
Hi, I have the same problem, and I did have an "incident" with my BB core. I did several hot/cold pulls and cleaned the opening of the nozzle with fine acupuncture needles of different diameters, but the problem still persists. The first cleaning blob of the PVA always, literally always, sticks to the nozzle and messes up the print afterwards.
I am using default settings ... any suggestions would be appreciated!
best, Georg
- 1 year later...
is it really works????
kmanstudios 1,073
Does PVA stick to glass?
Yes. Follow all the steps listed.
Level buildplate
Very clean glass
Thin layer of PVA based glue
I do not have issues with PVA on glass.
PVA? is that white glue and water?
PVA is a water soluble support filament, more infos here : https://ultimaker.com/en/products/materials/pva
A glue stick is normally based on PVA (not all) and has nothing to do with the filament. If you have PVA leftoulvers from your print, then you can mix it with water and you get an emulsion which is perfect for your bed adhesion instead of the glue stick. Why? Because it is the same result if you put on the emulsion on the glass or the glue stick.
kmanstudios 1,073
3 hours ago, ctdigger said:PVA? is that white glue and water?
Pretty ,much all it is.
So, Mix it very thin and just brush it on and let set? I thought I might not have the build plate hot enough at 60 degrees. White PLA seemed to work ok and Black PLA never stuck, even with the bed temp 100+ degrees.
I will let you know how it worked out. I bought a pc of Bisiliocristiline (spelling) figured it would fix the issue, not.
Thanks
kmanstudios 1,073
I just recycle my used PVA. Hate waste.
1
cloakfiend 972
I also hate waste!! but how do you recycle it? by using it as a glue? Id love to be able to recycle left over support PLA. Someone needs to make a decent reliable home extruder. Mind you PVA could be harder to extrude than PLA? Im doing my largest print ever (2 days, not that big by your standards mind you!) but 23 meters of filament and larger than my UM2 can print so have to use the S5, but Im guessing a lot of it is support. Just looking at the amount of it when I pour it into the bin afterwards upsets me.
kmanstudios 1,073
I just take the waste that I can break off and put it in water. Some will stick to the model and have to be 'melted' away with water, but for the most part you can break it off or clip it off and just soak it.
Nicolinux 287
Hey Markus,
sorry to hear about the problems. I have the same but I know they are being worked on.
PVA is particularly tricky to stick if bed leveling is not optimal. Did you use the default Cura 2.3.1 profile when slicing stuff? I think with that version a prime tower is used. If that's the case, you could increase the size of that tower (advanced settings).
