Hi Peggy -
Yes I did open the file you sent, but it was all-at-once and I need one at a time. I'm using a MakerBot M2, the latest version.
I am not using any Support or Adhesion, so Brim is not an issue. I tested more and found that the problem is regarding One-At-A-Time vs All-At-Once. Cura can slice All-At-Once but not One-At-A-Time, depending upon the accuracy/resolution. I can slice 25 parts if all at once.... but why can't it do it one at a time? Seems to be a bug to me.
Top Posters In This Topic
19
13
11
11
Popular Days
Mar 24
16
Mar 23
13
Apr 4
12
Apr 7
10
ahoeben 19 posts
nallath 13 posts
LePaul 11 posts
bagel-orb 11 posts
Popular Days
Mar 24 2017
Mar 23 2017
Apr 4 2017
Apr 7 2017
Posted Images
peggyb 170
I did sent you a project file with 9 items in it, can you open this?
I also asked what kind of printer do you have?
And warned you about the possibility that a brim is active by default that is 20 lines/7 mm wide, that takes up a lot of room around your model. Did you try to change this?
