Ultimaker Community of 3D Printing Experts
  • Sign Up
foehnsturm
Ultimaker Mark2 - The Smart Dual-Extrusion Upgrade
Posted · Ultimaker Mark2 - The Smart Dual-Extrusion Upgrade
Hi to all,
Yesterday I installed all the different parts of the mark 2.
I have to congratulate you for the great work you have done.
After setting the various parameters, now I would like to make some tests to verify the extruder offset, but i noticed these movement to the front-left corner
Are these movement an error or are they generated from the swap script?
Share this post
Did you try
With either
In Cura check: Travel->layer start x/y and set it to something like 100.0/50.0
or
Then you could activate the Mart2Tweaks Plugin
or both
you should be fine (up to my experience)
Share this post
Posted (edited) · Ultimaker Mark2 - The Smart Dual-Extrusion Upgrade
Hi! Long time lurker here :-)
First of all, i'd like to thank all of you for your efforts, the mods and prints are looking great!
I already upgraded my Ultimaker2+ with a second feeder, what i don't have is the mark2 extension board..but somehow i can't PM, i always get an Error 403 Forbidden when i try to send click on Send Message. Maybe because i didnt write any posts here? I don't know.
Anyway, long story short:
How can i get one? :-)
Thanks again!
Edit: ok, my account was classified as spam, therefore i couldn't post or send messages. Gonna PM Syntax Terror directly!
@TheFox, Sorry, did I miss your post?
Can can get everything from me here in Munich.
Share this post
Did you try
With either
or
or both
Yes, I have set the layer start and I activated the plug in
I don't know how but now I repeated the slice with the same settings and the travel movements are reduced, there is only one, I think it is start movement after a G28
Share this post
Edit_
No, I was wrong, that movement is a G28 at finished print.
The printer is running the last gcode and everything goes alright
Share this post
Thanks again!
i didn't get a respond from syntaxterror on my PM, so i thought he is busy and just waited...
sooo, can we hook up? :-)
gonna PM you! thanks
Share this post
Wait, what? I didn't get any PM?
yeah...strange. i just looked in my messages and the message isn't there :O
sorry! don't know what happend, was sure i sent it!
Share this post
HELP!!!
I have built The Smart Dual-Extrusion Upgrade and have run into a problem trying to run the gcode calibration set up.
When the heads go to the central prime position it causes my heads to crash against the front of the UM which then makes the print fail, and pick up/replace the second head fail as well.
I took the second head off when it did its prime (just the main head used) and measured the distance from the head to the front of the UM cabinet as 2.7mm, whereas the size of the 2nd head when attached is 3.0mm (ish).
Is there anyway I can alter the gcode to stop this happening - and of course change any Cura settings to stop this happening for later prints??
Any assistance much appreciated.
Andy
Share this post
First the obvious, you did install the Mark2 version of the firmware?
You did not start with the 2th already mounted? Although I think there should be a failsafe for this just be sure to have the 2th head docked at start.
  • Like 2
Share this post
HELP!!!
Andy
Check two things:
Make sure you got the latest version of the Cura definition files? There was an error with the initial start / prime positions in the first github version.
Second, in the firmware check Dual extrusion - > wiping position and set the y value to something like 40 mm.
Share this post
Well I have managed to stop the head hitting the UM2 casing :)
I held the 2nd head away until it was needed and managed to get some rough measurements which I entered, and on running the gcode file again the head remained well clear of the casing.
Print is looking good, with a small adjustment now required.
Many thanks to ultiarjan and foehnsturm for your assistance.
Andy
Share this post
do as foehnsturm advises :)
I also checked the setting of the prime positions in Cura, I trested this before on the UM3 and it worked, but somehow I can't get ti to work on the Mark2, maybe @tinkergnome knows why?
I set:primePos.thumb.png.c93f6be957ed2dfd8e449281866485fb.png
but it does not show in the menu's, although in the selection list it's now available for this machine.stillMissing.thumb.png.bb543bee32d21f408cada2f6204cc036.png
Share this post
HELP!!!
Andy
Check two things:
I'm not sure that is the same problem but if it is, it also happened to me, I solved by setting the extruder offset to X {+18} Y {-22} before run the calibration gcode.
It worked for me.
Share this post
Well, another Mark2 has joined the ranks, and I’m a very happy bunny :)
I decided to use my old UM2 stepper motor/head as it was laying around after updating to the 2+ and it always worked well in the past.
I had to mirror image and reprint IRobertl’s UM2 Feeder V2 and MendellS’s UM2 Filament straightener but this meant that I didn’t need to change the wires on the stepper motor to turn the right way – I did have to lengthen the stepper wires and change the esteps, but that was easily achieved in the firmware.
Parts for the head etc. were printed using ColorFabb XT, and seem to be holding up well.
The conversion was made super easy by using Syntax Terror’s expansion board (many thanks for supplying that gem).
Also a big thanks to the guys who made this possible, and also their kind assistance to help sort out a few teething problems on the way.
Kd5wvqW.jpg[/img]
LNEwohG.jpg[/img]
Andy
Share this post
Would it be possible to just drill the holes in the back of the case for the second extruder. This way I wouldn't have to worry about it hanging off the back of the printer
@Labern has a mirrored feeder assembly up on youmagine that works very well here.
Will look into that, think it is a nicer solution to place feeder n2.
Thanks!
  • Like 2
Share this post
Very nice, curious to see some prints...
just for everyone's info, you never have to change wire's for the stepper rotation direction, you can set the direction in the Mark2 firmware thanks to @tinkergnome's great work. Directly from the printers menu so anyone can do it.
Share this post
Here you go ultiarjan, my first attempt after doing a re-cal of the head :)
Printed at 0.15mm using Cura, which also is a learning curve for me as normally use S3D :(
Has anyone got any suitable S3D config files available yet?? Would be handy :)
I have ordered the new temp sensor and higher wattage heater as per the upgrade kit which will help when the 2nd head is required, but I think it works amazing - thank you and the other members of the team for your efforts <3
[url=bGGHfdV.jpg]
Andy
  • Like 2
Share this post
It shgould not be to hard to use S3D with the mark2, while you normally would do the T0 and T1 code for the head pick/place probaly in S3D, I think you should try to leave as much as possible to the Mark2 firmware.
The main avantage of using Cura is the temperature control around the tool change, with S3D you don't have this, so the print time wil go up. On the other hand looking at some of the strange behaviour of cura, strange pathplanning and retraction behaviour I can imaging you want to keep using S3D, just at least try and setup both....
As a start I think you can just use dual S3D, but leave out the XYZ offsets, as the firmware will handle it...
Share this post
[url=bGGHfdV.jpg]
Andy
I'm still amazed to see first ever dual prints of this quality. :)
  • Like 2
Share this post
Noob question about Cura..
Someone could explain me how can I select a custom profiles for mark 2? I changed some settings from a protected profile, I saved it as a custom but I can not activate it
Marco
Share this post
Absolutely blown away at how good they are coming out especially when I think the bigger heater and new temp sensor on the old head will improve things more.
My 2nd cone below.
Share this post
In that case I think I will persevere with Cura for 2 colour prints, and use S3D for single - Thanks for the information.
Share this post
Pretty much complete with the mod but I'm not having the best of luck to properly calibrate the hotends.
Docking works perfectly. I can switch hotends successfully. However, I suspect that I've gotten weak magnets (though its description says they're N52) which causes the 2nd hotend to fall during quick change while printing. Also, I hear ratlling noise the first time the 2nd hotend is picked up. I'm unable to determine the cause yet. I'll describe below hoping someone may be able to help.
Below are what I notice when printing dual material:
1. 2nd hotend is picked up.
2. Axis moves to front center and causes rattling noise as if the 1st hotend is squeezing the 2nd hotend against the front panel. (I'm not sure)
3. 2nd hotend extrudes material. Then moves to the left and cuts the extruded material. No issue here.
4. 1st hotend extrudes material. Same, no issue.
5.  Attempts to quickly park 2nd hotend misses the slot and 2nd hotend is dropped. Perhaps due to the squeezing/noise prior to this.
6. 1st hotend moves to front center banging to the pard 2nd hotend
7. Attempts to get the 2nd extruder but fails since the head is way off the parked 2nd hotend
8. I manually attach the 2nd hotend to help continue the printing but 2nd hotend prints way too off the expected area to print.
When the hotends are closest to the back panel, the bowden pushes the 2nd hotend and gets detached. I had to hold the 2nd hotend just to continue printing. Either I may have gotten a dud N52 or my bowden tubes are too stiff.
I've attached pics to show how off the hotends print. This is the calibration print.
Trying to print the 2-color traffic cone:
Share this post
That looks wrong...
Can you share pictures of the second printhead (coupled and in the dock) and feeder (where is it mounted)?
Are both UM2+ feeders/printheads or something different?
Also important: the settings on the printer for extruder offsets and wipe/prime position.
Share this post
    • Talking additive | The 3D printing podcast
      Why should we be the only ones asking questions? Join us and ask Jabil all your questions on September 22nd 5pm CET
      • 2 replies
    • Ultimaker masterclass: Optimizing your Ultimaker Cura workflow
      Save your seat for either broadcast on September 23.
      What will you learn?
      · Best practices for iterative print preparation and every lesson you should learn from each print
      · The right way to use per-object settings and when they are most useful
      · Easy-to-use resources for anyone who wants to develop their own printer definitions, plugins, or print profiles
      · How to optimize print profile settings and whether to “keep” or “discard” changes
      · When is the right time to export your drawing from CAD? (Based on Ultimaker Cura’s surprising power as 3D control software)
      · And a whole lot more tips and tricks!
      How can I join?
      This free masterclass will take place twice:
      1. 11am CEST (5pm SGT, 5am EDT)
      2. 5pm CEST (11am EDT, 8am PDT, 11pm SGT)
    • Do you use 3D printing at work? Let us know
      It doesn't matter if you are using 1 Ultimaker or 10, there is inspiration in everything. We're looking for ...
      • 1 reply
