Ultimaker Mark2 - The Smart Dual-Extrusion Upgrade
Posted (edited) · Ultimaker Mark2 - The Smart Dual-Extrusion Upgrade
Mark2 is an asymmetrical multi-extrusion upgrade for the Ultimaker 2, based on Foehnsturm's magnetic tool changer. It offers some unique features compared to conventional approaches.
Keep it smart and simple
The Mark2 upgrade doesn't require to modify or even disassemble the well-working single extrusion setup. Instead it adds a detachable second extruder. This leaves you with several benefits.
Powerful - print quality on par with eg. the UM3 or BCN3D Sigma
Flexible - use whatever you want: Olsson ruby, 3Dsolex block / nozzles, ...
Cost-efficient - all you need is a second drive train, some magnets and screws
Simple - all tried-and tested standard components
Smart - Z-offset managed by firmware, calibration wizards
Open & scalable - a non-extrusion tool head, a 3rd extruder ... all possible
Mark2 is an Ultimaker community project, we don't offer a complete kit but we can help you out with a package, including all the parts you need, besides the second drive train.
See it live
Probably the best way to get an impression of the usability and print quality is to watch a few videos.
https://www.youtube.com/watch?v=PLeNzDYMnqAqIeZHWU9iOWnj_2OaemupQG
Full Cura 2.5 integration
Mark2 comes with a set of Cura definition files and can be added as a pre-configured printer.
Tried and tested
Mark2 setups have been printing for more than 5.000 hrs now, which equals more than 500.000 tool changes. Beta-testers and co-developers include well-known guys here like Tinkergnome, Ultiarjan and many more.
The Mark2 website
ultimaker-mark2.com is the place where you find all the information you need for doing this upgrade.
... and The Mark2 Dual Extrusion Project Contest is still running.
  • Like 12
Posted · Ultimaker Mark2 - The Smart Dual-Extrusion Upgrade
Hi mark2 team,
wow awesome site and upgrade. i looked through the documentation and it looks great.
i do not want o hijack this thread but i guess the best start is here to find interested collaborators.
my "problem" is that i have an UMO (no plus) and would love to mod it to a Mark2 but not sure where to start.
- upgrade hotend and feeder to an um2+ x2 (if that is possible)
- simply use a double UMO hotend (eg i have the old dual extrusion kit is that possible to reuse it?)
- do i need the umo+ electronics ?
so many options and i am sure every version needs a lot of testing.
so here the question what is the best way to start and are there any interested makers out there?
thanks again for the awesome community upgrade.
    First, I think it's certainly doable.
    Lets start with firmware/electronics. @tinkergnome how difficult will it be to run it on the UMO board, assuming the rest of the machine is setup like the UM2, with same endstop positions,sliderblocks, UM2 hotend etc...?
    Regarding hardware I think converting to the UM2 hotend is the most reliable way to go, @neotko can you share the link to the conversion you did?
    Sure https://ultimaker.com/en/community/21167-assembly-manual-um2-upgrade-kit-on-ultimaker-original-plus
    The only issue I see hardware wise is that the 25W heaters 24V using 2 of them on a 19V old UMO board 1.5.X might get tricky. @amedee is much more an expert than me on UMO hardware and he's the @tinkergnome equivalent of UMO/UMO+
    So getting a china 75,- UM2 board is probably the easiest option? though you would also need a new power supply. It would save you 2x a pt100 board which would be needed to use the old UMO board.
    Does the UM2 firmware run ok on the UMO controler (display wise)?
    No it doesn't. Would be a 140€ upgrade china with screen. For that price I would just move the whole printer to duet3d.. but also that would need more modding
    Would you please show me the way where can I buy the Mark2 extension board?
    I am looking forward to upgrade my 3 Ultimaker 2+ in the elegant way!
    Cheers
    There is actually little advantage (not to say zero) in moving from a 1.5.x to a 2.1x board for this purpose.
    It is very reliable, probably much more than a Chinese 2.1.
    Running the board at 24v is not an issue either (just change the step-down to power the Arduino); PT100 are doing fine as well with the E3D adapter.
    The real issue is probably the firmware, as one need to backport the changes done for the UM2.
    Another potential issue is that the X/Y axes are inverted on the UMO, so they might be in the way for the docked head.
    Having said that, one should consider the total cost of the operation, an UM2 head upgrade + the second head + the mods is not a small budget for an experimental setup. It might be wiser to start from an UM2 and go with a proven solution...
    • Like 2
    Just visited the website. Great tutorial! When the second extruder arrives, i will test and post pics.
    Quick question. I have the UM2+ extended. Which firmware should I use:
    Mark2-dual-ext-17.02.2.hex
    Or
    Tinker-Mark2-extended-dual-17.02.2.hex
    I don't know if there are any differences?
    Ok Stupid Question coming up How do I download TinkerGnomes Software when I select the file I ge to see the code but no download... Sorry in advance ????
    Or
    The one with TINKER in the name is like the tinker firmware you may already know, it provides much more information in the display compared to regular Ultimaker firmware. The other is the regular Ultimaker firmware, with the Mark2 functionality added.
    My advice, get the TINKER.
    • Like 2
    Right click -> download will work fine. Or you could download all the files with the button clone or download
    https://github.com/foehnsturm/Mark2
    The easiest way to download from github is just to grab the ZIP file download and you get all files, printfiles, firmware, BOM, etc...
    Great work developing this!
    I have not been paying much attention to the previous thread. Is there anything you wish Cura would do or do differently that I can help with?
    Thanks very much!
    Answering your question: supporting 3 extruders sometime this year :)
    Well, and there are extra movements before and after a tool change occasionally generated by Cura, which we think are not necessary (in our case). Like extruder 2 travelling to a place just been visited by extruder 1 before moving to its "real" starting position.
    I'm sure some of the co-developers will come up with additional ideas :p
    Note that I'm a "frontend" guy, so I may not be able to help with the gcode produced by CuraEngine.
    Supporting 3 extruders should already be possible, by adding a third extruder.def.json file. Cura 2.6 will have a Custom FDM Printer that will let you configure up to 8 extruders.
    Building the Mark 2!!
    Printed all the parts and put them togheter, connected everything and tested.
    Use the thinkerware firmware version, everything is ok, docking and changing works superb!!
    Only one issue at this moment, my second hotend is my old UM2 one, and when i put everything together, my Z is wrong. The second head is higher as the first, making it impossible to print.
    I already tried raising the first hotend as much as possible, and lowering the second as much as possible, but still a few mm's between them 2, in the wrong direction....
    At this moment i "adjusted the height with putting some spacers between the printed part and the alluminium top plate of my second extruder.
    Hello, next question,
    The cura files on github, are they for windows only? i am a mac user....
    Greetings,
    Rudy
    You mean your 2th hotend has the old fixed UM2 block and not the olsson block?
    I see a few options;
    - change to an olsson block on the 2th also
    - adjust the plastic part of the head the be a few mm lower
    Do you know how to do CAD, the .stp files are on github. Let me know if I need to do it for you if you want option2, I can do it in the weekend, if needed tell me how many MM you need it to be lower, take a bit of a margin so it will most likely also work for other users...
    At this moment i put 5mm between the plastic part and the hotend unit. Works.
    So 5mm would do it for me, then there is 3mm of difference (second is lower now)
    I use 123d design, which cant read the files. If you could do it...
    In the end, if everything works out, i will buy a second olsson and bondtech extruder.
    Do you know a solution for the Cura config files on Mac?
    Thanks
    Sorry. Have not used a mac since the late nineties :)
    I was looking at the instructions and kept looking for some subtle warming about alignment of the magnets North or South :)
    Thanks
    I've only Macs. Just rightclick on Cura -> open package
    Then you see the directory structure and can move the files there.
